Trx with an Rsv Mille back end fettle !
Re: Trx with an Rsv Mille back end fettle !
You just gotta love these build threads.
						- Yoozy
Got the carbs sorted last night and the loom lashed on and all connected up round the front. If I wasn't going away for a few days today it would possibly be in a state to fire up. In a mocked up, lashed up kind of state
Gotta stay calm and not rush things
- Yoozy
SHE LIVES  Minor problem with having the coils the wrong way round, but thanks to MonseiurDimwiddyfookingenius she boooooooms like a guddun
Tiny coolant leak on that big silver bugger on the rocker to sort and the homeward stretch is upon me
 She's looking rather frikkin nice annall
Fingers crossed by the end of the week and its fandabyfoorkindozy
The coolant pipe can be a bit of an arse.
Reassembled mine not long ago with a new O-ring and it still leaked (but then sorted itself out).
The head (and the pipe) get badly corroded within the pocket where the seal sits and the seal surfaces become pitted.
A dollop of Yamabond sealant with a new seal should be good.
- Yoozy
That's the fella, about 1" diameter. Seems to have cut itself when pressing the pipe in. Easy enough to mend
						- Yoozy
- schmiffee
Oh see, I would prefer them where they are on the inside...let a little more of the frame SHINE!!coxylaad wrote:I would pull them out a bit so they are not recessed on the inside of the tubes.
				bubbaad
Yeah.....Frame showing for me but not the shiny black. Maybe something that contrasts with the frame a little. Bike's coming along well mate, looking forward to seeing it finished
						- Yoozy
Carbon it is boys. Headlight, winkers and horn all nailed on and wired up tonight. Just gotta get some clocks on and we're off
						- Yoozy
				zednine
Well I like it .......... nice build and summat looking smart at the end ........ well done mate
						- sadmansteve
You need to sort those throttle cables! how long are they?  Invert the cable housing or use an R6 2CO housing and have the cables exit under the handle bar, it will look neater than them stuck up in the air. By doing this they also take a shorter route and you don't need extended cables.
						- Yoozy
Eye, that's on the list along with some black brake lines. Other than that it's ok then
						- dixonj
Job sorted, maybe have to try for another meet up.
