I'll start with a mod list.
870cc pistons
Head flowed by some chap at Cosworth
Over cams
FCR39's
Full Akro
WP/USD forks
320mm PFM discs, grabbed by a pair of 6 pot Billets
ECU earthing mod (picked up 5hp through this alone)
FZR400 headlght.
I'll post the dyno charts when I get them, but the curve is mad, almost peak torque at 3000rpm and flatlines till 9000rpm then peters off slightly thereafter. It'll hit redline in top on standard gearing. It's making about 90hp at the wheel, although the torque curve rings my bells more than HP, but 90 is mighty respectable IMO and let's not forget this was built in 1996, before big BHP twins were as common as they are now. As far as the noise goes, well it makes the hairs on the back of my neck stand up, everything within a 5 metre radius just shudders and resonates when the engine is revved and the only noise from the engine apart from RAAAARRR!!!!! is the tappety tap of the flatslides, no usual TRX clunk and clatter, this is one tight built engine.
just got to get a decent rear shock, maybe Wilbers, and get Darren at MCTechnics to set it up and change the springs in the forks and that should be it.
I know Chris won't read this, but I just want to say thanks for doing such a good job and I look forward to ragging the arse off it as soon as it's insured.
Phuk72 will vouch that I'm not just spamming for Xbikes.
