runnin rich
- Banger
runnin rich
can any one tell me the various reasons my bike should start running rich after the bafflectomy I would of thought free-er flow would lean it off a bit
									the TRX made me do it officer!
						- steve speed
Re: runnin rich
could just be coincidence ,, its normally emulsion tubes ,, how many mile has the motor done ????
						- Banger
- Killerwhale
Re: runnin rich
Scavange (spell check) gas easier/more freely so it draws in more fuel?Banger wrote:can any one tell me the various reasons my bike should start running rich after the bafflectomy I would of thought free-er flow would lean it off a bit
If it´s really rich now and you don´t have a K&N filter you can probably get a few ponies more....and open up the airbox
- G Beale
Re: runnin rich
Tubes are 20 quid each mate, Yamaha or factory pro. I would be amazed if yours weren't showing signs of wear. Mine were at 16K. Symptoms are very jerky, on-off throttle from closed & poor mpg.
									 Life's short & it's hard.... .    like a body building elf.
						- Killerwhale
Re: runnin rich
But richer after baffelectomy??G Beale wrote:Tubes are 20 quid each mate, Yamaha or factory pro. I would be amazed if yours weren't showing signs of wear. Mine were at 16K. Symptoms are very jerky, on-off throttle from closed & poor mpg.
- Banger
Re: runnin rich
thats the fella! is there anything else need changing at same time as the tubes i.e needles etcG Beale wrote:Tubes are 20 quid each mate, Yamaha or factory pro. I would be amazed if yours weren't showing signs of wear. Mine were at 16K. Symptoms are very jerky, on-off throttle from closed & poor mpg.
						- Banger
Re: runnin rich
I think steves right just coincidence if im true it was a little hesitant from closed throttle before bafflectomy
						- Wombat
 - Forum Marsupial
Re: runnin rich
I've heard rumour that they can wear as early as 5,000kms.
I had mine done 2 or 3 years ago and replaced with Factory Pro and I'm sure mine are worn again at 72,000kms. Might try Dynojets next.
						- steve speed
Re: runnin rich
factory pro ones  should last longer because they are nickle plated
						- G Beale
Re: runnin rich
I just changed the tubes & nothing else. Can't see the needles wearing out on standard brass tubes. They say to change float bowl gaskets but if they're not damaged ???Banger wrote:thats the fella! is there anything else need changing at same time as the tubes i.e needles etcG Beale wrote:Tubes are 20 quid each mate, Yamaha or factory pro. I would be amazed if yours weren't showing signs of wear. Mine were at 16K. Symptoms are very jerky, on-off throttle from closed & poor mpg.
						- Banger
- Banger
- G Beale
Re: runnin rich
No part number sorry but you might find this thread useful when you replace them.
http://trx850.motomaniac.net/forum/view ... =36&t=1386
The needle jets or emulsion tubes aren't easy to identify from the parts list either.
http://trx850.motomaniac.net/forum/view ... =47&t=2543
