runnin rich
Banger
runnin rich
Post by Banger » Wed Jun 17, 2009 7:57 pm
can any one tell me the various reasons my bike should start running rich after the bafflectomy I would of thought free-er flow would lean it off a bit :?:
the TRX made me do it officer!
steve speed
Re: runnin rich
Post by steve speed » Wed Jun 17, 2009 8:13 pm
could just be coincidence ,, its normally emulsion tubes ,, how many mile has the motor done ????
Banger
Re: runnin rich
Post by Banger » Wed Jun 17, 2009 8:28 pm
38000 miles, how much are emulsion tubes on average?
Re: runnin rich
Post by Killerwhale » Wed Jun 17, 2009 8:36 pm
Banger wrote:can any one tell me the various reasons my bike should start running rich after the bafflectomy I would of thought free-er flow would lean it off a bit :?:
Scavange (spell check) gas easier/more freely so it draws in more fuel?
If it´s really rich now and you don´t have a K&N filter you can probably get a few ponies more....and open up the airbox :-)
G Beale
Re: runnin rich
Post by G Beale » Wed Jun 17, 2009 9:00 pm
Tubes are 20 quid each mate, Yamaha or factory pro. I would be amazed if yours weren't showing signs of wear. Mine were at 16K. Symptoms are very jerky, on-off throttle from closed & poor mpg.
Re: runnin rich
Post by Killerwhale » Wed Jun 17, 2009 9:08 pm
G Beale wrote:Tubes are 20 quid each mate, Yamaha or factory pro. I would be amazed if yours weren't showing signs of wear. Mine were at 16K. Symptoms are very jerky, on-off throttle from closed & poor mpg.
But richer after baffelectomy??
Banger
Re: runnin rich
Post by Banger » Wed Jun 17, 2009 9:16 pm
thats the fella! is there anything else need changing at same time as the tubes i.e needles etc
Banger
Re: runnin rich
Post by Banger » Wed Jun 17, 2009 9:18 pm
I think steves right just coincidence if im true it was a little hesitant from closed throttle before bafflectomy
Wombat
Forum Marsupial
Re: runnin rich
Post by Wombat » Fri Jun 19, 2009 1:54 pm
I've heard rumour that they can wear as early as 5,000kms.
I had mine done 2 or 3 years ago and replaced with Factory Pro and I'm sure mine are worn again at 72,000kms. Might try Dynojets next.
steve speed
Re: runnin rich
Post by steve speed » Fri Jun 19, 2009 7:44 pm
factory pro ones should last longer because they are nickle plated :D :D
G Beale
Re: runnin rich
Post by G Beale » Fri Jun 19, 2009 8:12 pm
I just changed the tubes & nothing else. Can't see the needles wearing out on standard brass tubes. They say to change float bowl gaskets but if they're not damaged ???
Banger
Re: runnin rich
Post by Banger » Fri Jun 19, 2009 8:29 pm
thanks for that :D
Banger
Re: runnin rich
Post by Banger » Fri Jun 19, 2009 8:37 pm
anyone have a part number for emulsion tubes?
G Beale
Re: runnin rich
Post by G Beale » Fri Jun 19, 2009 10:13 pm
No part number sorry but you might find this thread useful when you replace them.
http://trx850.motomaniac.net/forum/view ... =36&t=1386
The needle jets or emulsion tubes aren't easy to identify from the parts list either. :x
http://trx850.motomaniac.net/forum/view ... =47&t=2543
