Aussies and kiwis please help
				col
Has anyone got a reg/rec they could sell me for not stupid money.
I'm in NZ and the TRX was never very popular here.
pm me please if you can help
- schmiffee
Re: Aussies and kiwis please help
Hi Col,
I know you said to pm you, but I found this website reasonably useful so I thought I'd post it so others can encounter it also. The website is www.trademe.co.nz and if you copy/paste this link (http://www.trademe.co.nz/Browse/SearchR ... ype=Search) into your browser window it comes up with a fair few TRX's - varying price range. Hope this helps
				col
i think we've got crossed lines here.
I've already got a TRX, i just need a regulator/rectifier
- schmiffee
Ah I see...well that site may also help you...apart from that maybe evilBay or even findapart.com (works in Aussie - dunno about NZ). Hope that helps a bit more
- Kayla
Is this any use?
http://shop.wemoto.com/pictures.dyn?u=2147986qqq25671
It looks like the same reg/rec that's fitted to a lot of Yamahas (probably most, given Yam's parts sharing), it's certainly the same as the TZR250. Maybe you could find one from another model and mod it to fit? I think it's three phase in from the genny and single phase (12V) out, earthed to the frame.
- Quan-Time
www.findapart.com.au failing that try http://www.motorcycle-parts.com.au/Yamaha_Road.htm
they list TRX850 stock, and upgraded items.
I run bigger coils, computer and a LCD screen, and i run off the stock alt / RR.. so you should be fine.
Hope this helps
PS: a TDM850 should be the same, so try show and go motorcycles in adelaide. They will probably reply on findapart.com.au...
Hope this helps
				col
cheers guys, all sorted for now.
