changing front sprokets
steve speed
Re: changing front sprockets
Post by steve speed » Mon Apr 28, 2008 12:00 pm
if you have a 110 link chain (which is std ) you can fit a 42 rear no problem ,i have a 17/42 setup with a 110 link chain and it is by far the best compromise
Post by Killerwhale » Mon Apr 28, 2008 2:10 pm
steve speed wrote:if you have a 110 link chain (which is std ) you can fit a 42 rear no problem ,i have a 17/42 setup with a 110 link chain and it is by far the best compromise
I would say 16/41
thumpa
Re: changing front sprokets
Post by thumpa » Mon Apr 28, 2008 2:53 pm
killerwhale - wouldnt that be too much of a "wheelie" machine then?
steve speed
Post by steve speed » Mon Apr 28, 2008 3:03 pm
when i tried 16/42 it was a one wheel monster......................fun though
Post by Killerwhale » Mon Apr 28, 2008 9:37 pm
thumpa wrote:killerwhale - wouldnt that be too much of a "wheelie" machine then?
Nahh, 320Kg with me on there...~90hp....wheeliemachine?? I would think not.
I rode it a couple of day´s with 15/40....that was kinda hysterical....Would do great on a twisty track though...
thumpa
Post by thumpa » Tue Apr 29, 2008 5:06 am
does that gearing stress out the motor? or would it be less stress?
Post by Killerwhale » Tue Apr 29, 2008 7:02 am
thumpa wrote:does that gearing stress out the motor? or would it be less stress?
I would think it stresses more as it goes to 180kmh in WAY less time....and it keeps pulling straight thru the reds.. :roll:
Kevtrx849
Moderator
Post by Kevtrx849 » Tue Apr 29, 2008 7:02 pm
I would have thought a 15 tooth front sprocket would chainsaw thru the swingarm or at least make short work of the guide. :shock:
( HENRY FORD )
Post by Killerwhale » Tue Apr 29, 2008 8:08 pm
Kevtrx849 wrote:I would have thought a 15 tooth front sprocket would chainsaw thru the swingarm or at least make short work of the guide. :shock:
Chainangle where steeper but not as bad as i thought actually, i guess testing stuff is the only way! ;-)
