Increase of revs when in gear...!
Post by Killerwhale » Sat Apr 19, 2008 5:36 pm
Has anyone experienced this, fekkin strange me thinks.
Sometimes the revs picks up when going to first or second gear at a standstill....when going neutral it at once drops to 1200rpm.
Whatcha reckon?? :shock:
Re: Increase of revs when in gear...!
Post by slow codger » Sun Apr 20, 2008 10:41 pm
:? Can you clarify whether the clutch is in, is the throttle cable sticking?, or part of carbs sticking ( thats all abit teccy for me, but crap in carbs not allowing the mechanism to close properly).
Post by Killerwhale » Mon Apr 21, 2008 7:07 am
slow codger wrote::? Can you clarify whether the clutch is in, is the throttle cable sticking?, or part of carbs sticking ( thats all abit teccy for me, but crap in carbs not allowing the mechanism to close properly).
I don´t have the right hand on the throttle at all....just shifting gear when standing still!
Red Rex
Post by Red Rex » Mon Apr 21, 2008 8:02 am
... when you pull the clutch in?
Is it something as simple as the clutch cable flexing and moving the throttle cable ??
Post by Killerwhale » Mon Apr 21, 2008 8:38 am
Red Rex wrote:... when you pull the clutch in?
No no, when putting bike into gear....one or two does not matter...
madivi
Post by madivi » Mon Apr 21, 2008 4:27 pm
Really misterious.
Even if the gear would influence the ECU, how would this relate to the carburetor?
I guess there is no connection at all between the two.
Could it be that your carburetor's membranes are defective (cracks)?
This can drive your idling crazy randomly (I have this on my XS).
(My profile is still as stock as my Trixie is, this might change)
Post by Killerwhale » Mon Apr 21, 2008 5:25 pm
madivi wrote:Really misterious.
Little over year old FCR´s...would think they are ok.
A mystery it is!! :shock:
Post by youngy » Mon Apr 21, 2008 10:32 pm
I can only think it is clutch drag
Post by Killerwhale » Tue Apr 22, 2008 5:42 am
youngy wrote:I can only think it is clutch drag
Wouldnt that mean a decrease in revs... 8-[
madivi
Post by madivi » Tue Apr 22, 2008 6:07 am
Clutch drag? Due to bearings and cogs?
How is the clutch to cause drag?
Maybe KW has a clutch with negative drag coefficient :twisted:
Post by HansJ » Tue Apr 22, 2008 6:59 am
That's a good suugestion, gets my vote! :wink:
Post by Killerwhale » Tue Apr 22, 2008 7:17 am
Öhhh, it does NOT happen when pulling the clutch. I can hold the clutch in for 10 minutes and nothing....but when put into gear....2k revs. And it don´t happen all the time.
Thinking further, this happened when going for MOT and i put the dB-killers in...fluke or not....i don´t know.
Post by Killerwhale » Thu Jun 05, 2008 8:31 pm
Well, this is still a problem so i bump it!
....now it got worse, clutch in the whole time....1st or 2nd=2-2500 revs.....click it in neutral and drops to 1200.
No wonder i have trouble get the gears in when riding!! ...and i thought it was the new oil....bah!
Post by slow codger » Fri Jun 06, 2008 1:51 pm
:? Ok teccy head on today, You say that it revs to 2000 - 2500 when in gear, but as soon as you put it in neutral it drops to 1200 revs. My thoughts are that you are running on choke for those high revs in neutral, so have you checked the choke cable is free. Also check the neutral wires to see if they are affecting the ECU.
Post by Killerwhale » Fri Jun 06, 2008 2:52 pm
slow codger wrote::? Ok teccy head on today, You say that it revs to 2000 - 2500 when in gear, but as soon as you put it in neutral it drops to 1200 revs. My thoughts are that you are running on choke for those high revs in neutral, so have you checked the choke cable is free. Also check the neutral wires to see if they are affecting the ECU.
I have FCR´s so no choke here...
I have very little throttle play as is so i will fix that...then i guess it´s just electrical left...!? :shock:
