Your personal thought on dogbones...
Post by Killerwhale » Fri Feb 08, 2008 6:45 pm
Yes, what´s your ideas about them bones?
I got the KEDO one´s and they lift 4cm....wich feel a tad much even if it actually looks the shit.
But i think that the Ohlin shock can´t work it´s magic with that raise..
Whatcja think folks!?
cheesie
Post by cheesie » Fri Feb 08, 2008 10:46 pm
I did,nt like mine and they only raised the back about 15-18mm, that was at 177mm hole centres, I have another set at 180 hole centres, I never done it for looks my centre stand dug in last year and wanted to give myself a little more ground clearence though I blame the stand digging in more on the sort of corner and me weighing in at nearly 17 stone at the time now 16 :D
Post by youngy » Fri Feb 08, 2008 10:50 pm
I had them on a previous TRX and they were too high. I also found that I could not compress the shock even on the softest preload setting.
cheesie
Post by cheesie » Sat Feb 09, 2008 10:14 pm
just tried the new dogbones and it is much better would be realy good for the track, think I will pull the yolks back up the forks another 2mm to just below standard hight the 180 hole centre dogbones lift the rear by 6-8mm they are 2001 zx6r dogbones
pwmotorsports
Re: Your personal thought on dogbones...
Post by pwmotorsports » Sat Feb 23, 2008 8:21 pm
So do you all have diffrent ones or do the yzf ones come in differing sizes ?
Post by Killerwhale » Sat Feb 23, 2008 8:28 pm
pwmotorsports wrote:So do you all have diffrent ones or do the yzf ones come in differing sizes ?
I have KEDO´s own stuff....raises 40mm on the rear.
Post by Quan-Time » Sun Feb 24, 2008 12:01 pm
wow.. 40mm is a HUGE amount. As you said, i dont think the shock is gonna work properly at that height. But i could possibly be wrong.
Dogbones are different for every person.. Some like this, others like that.. Find whats best for you really.
Post by Killerwhale » Sun Feb 24, 2008 12:03 pm
Quan-Time wrote:wow.. 40mm is a HUGE amount. As you said, i dont think the shock is gonna work properly at that height. But i could possibly be wrong.
The Ohlins shock has height adjuster so i will lower it and try if it´s better.
....but hey, it looks really good! 8)
steve speed
Post by steve speed » Sun Feb 24, 2008 12:20 pm
i am up to 40mm now with the adjuster on the ohlins ,in an attempt to get some more weight over the front ,,the forks with the back jacked up are now 23.5 deg, and there is still no head shake,, this is an attempt at getting more feel from the front and its getting better ,, but i doubt i will be able to make it handle like the buell , strange thing is buell run 21 deg forks with no problems :D :D
pwmotorsports
Post by pwmotorsports » Sun Feb 24, 2008 7:03 pm
so yzf ones give me what over stock?
Post by Tarwetijger » Sun Feb 24, 2008 8:35 pm
Don't know about the TRX originals, but the YZF dogbones measure 170 mm.
Maybe someone else can post the TRX measurement?
Post by Killerwhale » Sun Feb 24, 2008 8:42 pm
Tarwetijger wrote:Don't know about the TRX originals, but the YZF dogbones measure 170 mm.
I have an extra set at work....if no one beat me to it....
steve speed
Post by steve speed » Sun Feb 24, 2008 9:05 pm
as best as i can measure them on the bike they are 183mm centres :D :D :D :D
Post by Killerwhale » Mon Feb 25, 2008 8:09 am
steve speed wrote:as best as i can measure them on the bike they are 183mm centres :D :D :D :D
Guess i got beat! =D>
steve speed
Post by steve speed » Mon Feb 25, 2008 10:18 am
yes you did but iam probably wrong :D :D :D :D
