Do I have a problem ?
Red Rex
Post by Red Rex » Sun Jan 27, 2008 5:31 pm
'Rex has been garaged for the winter, only being run up every 2 or 3 weeks. A couple of weeks back when I started her it was a bit of a struggle to get her to fire and then she would run on only one pot (the LH one). Figured it was an oiled plug on the RH pot :roll:
Cleaned that plug and she started straight away and ran perfectly. After a 5 mile ride tick-over was smooth and steady at 1100 rpm. Problem solved :?:
Today I start her up after a struggle and this time she runs on one pot again (this time the RH one) and I have to replace the LH plug. Again all is perfect after a 40 mile trouble-free ride. :shock:
Was it a coincidence ?? Was I just unlucky ?? Or is this the early sign of a potential problem with emulsion tubes.
BTW 'Rex has done 30k miles.
Opinions welcome.
Post by youngy » Sun Jan 27, 2008 7:16 pm
Cold and damp getting to your plugs I reckon. New plugs will cure it.
Post by Jak » Sun Jan 27, 2008 9:35 pm
^ what he said ... and yet again (amazing as it sounds) I knew an answer :wink: Only coz mine does the same if it's left for a little while.
My old Guzzi was temperamental about starting - I used an old thick blanket to tuck it in at night and all was good :D been doing that this winter with the TRX and haven't had much of a problem.
Red Rex
Post by Red Rex » Tue Jan 29, 2008 9:08 am
Thanks for the replies. Hopefully the 'problem' will go away now she's had a decent run out on a dry day.
The only reason I thought it might be something other than the usual is that the garage is more like a living room (fitted carpets / TV / stereo / double-glazed) so not cold and damp, and the plugs were replaced about 500 miles ago. That and the fact that it has happened on two consecutive weekends.
Post by Tarwetijger » Tue Jan 29, 2008 9:13 am
Red Rex wrote: The only reason I thought it might be something other than the usual is that the garage is more like a living room (fitted carpets / TV / stereo / double-glazed) so not cold and damp, 8<
:notworthy:
And what about you, do you sleep in the garage?
Post by youngy » Tue Jan 29, 2008 2:57 pm
Maybe your carbs are knackered then
Red Rex
Post by Red Rex » Tue Jan 29, 2008 8:20 pm
... come close on a couple of occasions !!
... do you really think so ?
Post by youngy » Tue Jan 29, 2008 8:58 pm
Red Rex wrote: Maybe your carbs are knackered then
no..........................(devilish laughter)
Post by ekoja » Tue Jan 29, 2008 9:47 pm
Mine started doing that, hard to start when cold, I had the valves checked, and adjusted, no more problems. Altho I also had the carbs checked as well, but they did say the carbs were fairly well adjusted. (unlike some people I know :wink:)
Glen1TRX
Post by Glen1TRX » Wed Jan 30, 2008 9:52 am
ekoja wrote: (unlike some people I know :wink:)
Care to elaborate :cry:
time fades away
Post by ekoja » Wed Jan 30, 2008 11:23 am
Mostly family (mine) and every XPT passenger I have ever encountered.
XPT is a train that I get the priviledge to carry passengers for, (for the benifit of all you outside of Aussie) Just about all the people we carry are bloody feral. :cry:
