Rain
bernardo
Rain
Post by bernardo » Fri Jan 11, 2008 8:55 am
anybody had trouble with misfires in the rain?
Mine normally runs fine but started misfiring last night, cleared up with a squirt of WD 40 when I got home, but started missing again after a couple of miles this morning.
Last bike I had that did this I had to change the coils
kebab19
Post by kebab19 » Fri Jan 11, 2008 9:05 am
Mine also did it in heavy rain - down to one cylinder then the 2nd suddenly cut in and spun the rear - disturbing!
I replaced the coils and she is now fine.
1996 vintage now sold. 1999 FZS600 Fazer, 2006 YBR125 & 1981 RD350LC left to keep me entertained.
bernardo
Post by bernardo » Fri Jan 11, 2008 12:10 pm
Kinda figured that might be the answer.
did you use standard Yamaha coils or Dynacoils or something else?
Kevtrx849
Moderator
Post by Kevtrx849 » Fri Jan 11, 2008 1:35 pm
Mine did it once many moons ago in very heavy rain. Kept spluttering and cutting out but managed to get it home. Once it dried out the problem was gone.
( HENRY FORD )
Post by slow codger » Fri Jan 11, 2008 2:39 pm
:oops: And who remembers metal spark plug caps?
TonyDevil
Post by TonyDevil » Fri Jan 11, 2008 6:01 pm
wet running is a common problem on the TDM & XTZ, they dont all do it, but a significant number do
the answer is to seal it up using amalgamating tape on the leads/coils (after drying it out ofcourse)
TDM900 2003 - commuting tool
Z750 hardtail - project
HolerTogni
Post by HolerTogni » Fri Jan 11, 2008 6:50 pm
Hi Dave!
slow codger wrote::oops: And who remembers metal spark plug caps?
O yes, the lightning down there was amazing everytime!
Remembering greetings from Munich!
steve speed
Post by steve speed » Fri Jan 11, 2008 9:43 pm
TonyDevil wrote:wet running is a common problem on the TDM & XTZ, they dont all do it, but a significant number do
can you tell us whats,, amalgamating tape , :? :? :?
steve speed
Post by steve speed » Fri Jan 11, 2008 10:12 pm
thanks martin,, do you wrap all the coil or just the connections ??we have a maplins in manchester :lol: :lol:
burty
Post by burty » Fri Jan 11, 2008 10:20 pm
I bit of silicone around the point where the leads exit the coils works on Bandits. (Mine used to suffer terribly in the wet).
Never had a problem with the TRX, despite riding through foot deep water this morning.
bernardo
Post by bernardo » Mon Jan 14, 2008 5:45 pm
Thanks guys, I did notice that the coils are very exposed, once the WD40 came out :evil:
maybe if they were n't so exposed this wouldn't be a problem, but London rush hour in the dark and rain with a misfiring bike was crap.
Thanks for all your help
bernard
Post by ekoja » Mon Jan 14, 2008 9:03 pm
Old codger thread drift mode on
Who of you remembers the early Mini's
The distributor (remember them) was at the front of the motor behind the grill and in even reasonably heavy rain, the dizzy would get wet and the bloody things would cease to function, leaving the owners stranded on the side of the road. Once the heat from the engine had dried them out away they went again.
The problem was solved when a rubber cover was fitted over the distributor cap, to replace the various home made efforts which usually consisted of plastic shopping bags and insulating tape.
O.C.thread drift off
twolfe
Post by twolfe » Mon Jan 14, 2008 10:17 pm
Morry 1100's as well Ash.
Post by ekoja » Mon Jan 14, 2008 10:46 pm
twolfe wrote:Morry 1100's as well Ash.
Yep, they were even worse, it only had to look like rain and they stopped.
