O-RING
marky19
O-RING
Post by marky19 » Wed Dec 10, 2025 7:58 pm
hi all, does any one know the best way to remove the small o-ring part number #1AE-14227-00 from the block jet assy part number #3GM-1411A-00 this is from a FZR1000 (3GMG,1995)
Re: O-RING
Post by dicky » Thu Dec 11, 2025 10:00 pm
Its a very long time since I had carbs pulled down to that level, but I think the O ring came out on the end of the slide housing. If yours is still stuck in the carb body then I'd just scrape it out as it's probably perished. Replace everything on the carbs with a Viton kit from Litetek.
https://litetek.co/Carb_Kit_Yamaha_TRX850.html
marky19
Re: O-RING
Post by marky19 » Fri Dec 12, 2025 10:49 pm
hi dicky, thanks for your reply, the problem is the o-ring has moved farther down the brass inner tube and i cant dig it out, please bare in mind that this part #3GM-1411A-00 is from a fzr 1000 (1995) not a trx.
many thanks again........
Re: O-RING
Post by dicky » Fri Dec 12, 2025 11:41 pm
A picture might helps us understand better, but unfortunately you can't simply upload it to the forum. Stick a pic on Flickr etc and link to it.
The carbs are both Muikuni BDST's and are almost identical.
Litetek also have kits for FZR1000's.
Viton gaskets and O rings don't perish and the kits from Litetek are ridiculously cheap.
