pom in nz
by pom in nz » Mon Apr 30, 2012 8:58 am
hey peoples, which jet kit would you recommend to me, dynojet or factorypro.
my bike has custom headers/exhaust system and pod filters, motor is stock as are the carbs, well appart from 150 main jets.
i was thinking of the dynojet stage 3 tdm kit.
and yes i know flat slides are the way to go but i cant afford them
...........................yet
any comments would be most welcome
by Mincehead » Mon Apr 30, 2012 6:46 pm
Factory pro emulsion tubes (nickel plated) and Yamaha or dynojet needles. The Facyory Pro needles are bitches to set up apparently, although that`s from my time here and what others have posted.
I personally have no direct experience with them as I junked the stock carbs as soon as I could.
M.V.
by M.V. » Tue May 01, 2012 12:19 am
I went with Factory Pro, I had no trouble setting them up, but I did get 2 dyno runs, before & after & made some changes based on the A/F readout, so your mileage might vary...
