r1 forks?
- pwmotorsports
r1 forks?
ok so can i just slide out the trex forks and slide in the r1 forks or will i need to mod the wheel aswell ? brakes are fine now ive got the r1 master cyinder and the blue spots on the trex just want to put some better forks in but if its to much hassle prob wont bother
Re: r1 forks?
Go thru this:pwmotorsports wrote:ok so can i just slide out the trex forks and slide in the r1 forks or will i need to mod the wheel aswell ? brakes are fine now ive got the r1 master cyinder and the blue spots on the trex just want to put some better forks in but if its to much hassle prob wont bother
http://trxfiles.webgti.net/zip_files/r1fork.zip
Re: r1 forks?
No, R1 forks are a much greater diameter so need bigger yokes. You'll also loose speedo drive, need an R1 wheel, disc, spindle, mudguar and clip onspwmotorsports wrote:ok so can i just slide out the trex forks and slide in the r1 forks or will i need to mod the wheel aswell ? brakes are fine now ive got the r1 master cyinder and the blue spots on the trex just want to put some better forks in but if its to much hassle prob wont bother
what you want is something like this
http://trx850.motomaniac.net/forum/view ... =33&t=2563
- pwmotorsports
Re: r1 forks?
want to keep me only just fitted new flatbar top yoke really speedo drive not an issue ive fitted a vapor anyway
Re: r1 forks?
You'll need 41mm forks thenpwmotorsports wrote:want to keep me only just fitted new flatbar top yoke really speedo drive not an issue ive fitted a vapor anyway
Just like the ones I'm selling
- pwmotorsports
Re: r1 forks?
What Yammys have 41mm forks out of interest ?
- pwmotorsports
Re: r1 forks?
would think thunderpants forks wouldnt be to bad on the old wallet are they able to take the orginal whel disks etc or do i need all that aswell ?
Re: r1 forks?
Last set of Tcat forks went on ebay for £221 IIRCpwmotorsports wrote:would think thunderpants forks wouldnt be to bad on the old wallet are they able to take the orginal whel disks etc or do i need all that aswell ?
You can make the TRX wheel fit but you need spacers etc and a new mudguard.
