r1 forks?
pwmotorsports
r1 forks?
Post by pwmotorsports » Wed Feb 20, 2008 2:16 am
ok so can i just slide out the trex forks and slide in the r1 forks or will i need to mod the wheel aswell ? brakes are fine now ive got the r1 master cyinder and the blue spots on the trex just want to put some better forks in but if its to much hassle prob wont bother
Re: r1 forks?
Post by Killerwhale » Wed Feb 20, 2008 8:05 am
pwmotorsports wrote:ok so can i just slide out the trex forks and slide in the r1 forks or will i need to mod the wheel aswell ? brakes are fine now ive got the r1 master cyinder and the blue spots on the trex just want to put some better forks in but if its to much hassle prob wont bother
Go thru this:
http://trxfiles.webgti.net/zip_files/r1fork.zip
Re: r1 forks?
Post by phuk72 » Wed Feb 20, 2008 9:59 am
No, R1 forks are a much greater diameter so need bigger yokes. You'll also loose speedo drive, need an R1 wheel, disc, spindle, mudguar and clip ons
what you want is something like this :wink:
http://trx850.motomaniac.net/forum/view ... =33&t=2563
pwmotorsports
Re: r1 forks?
Post by pwmotorsports » Wed Feb 20, 2008 12:06 pm
want to keep me only just fitted new flatbar top yoke really speedo drive not an issue ive fitted a vapor anyway
Re: r1 forks?
Post by phuk72 » Wed Feb 20, 2008 12:12 pm
pwmotorsports wrote:want to keep me only just fitted new flatbar top yoke really speedo drive not an issue ive fitted a vapor anyway
You'll need 41mm forks then
Just like the ones I'm selling :wink:
pwmotorsports
Re: r1 forks?
Post by pwmotorsports » Wed Feb 20, 2008 3:08 pm
What Yammys have 41mm forks out of interest ?
Re: r1 forks?
Post by phuk72 » Wed Feb 20, 2008 3:12 pm
TRX850 and Thundercat
Possibly older FZRs?
pwmotorsports
Re: r1 forks?
Post by pwmotorsports » Wed Feb 20, 2008 4:06 pm
would think thunderpants forks wouldnt be to bad on the old wallet are they able to take the orginal whel disks etc or do i need all that aswell ?
Re: r1 forks?
Post by phuk72 » Wed Feb 20, 2008 6:12 pm
pwmotorsports wrote:would think thunderpants forks wouldnt be to bad on the old wallet are they able to take the orginal whel disks etc or do i need all that aswell ?
Last set of Tcat forks went on ebay for £221 IIRC
You can make the TRX wheel fit but you need spacers etc and a new mudguard.
