100/80w headlight
100/80w headlight
Has anyone had any problems with the lens getting too hot when fitting a 100/80 headlight bulb?
Re: 100/80w headlight
I used one with mine for quite a while and had no problems.
				vicar
Got a 130/90 in mine its been in for more than a year and I run with the lights on all of the time.
Had no problems Vic
									Had no problems Vic
IF only one bike was enough.......................(still room for another one)
Thanks for the responses guys - I just found a 100/80 in my garage I forgot I had - I'll shove it in - the wiring looks up to it by modern vehicle standards
- Kenny
Is that with a relay or straight off the std wiring loom?vicar wrote:Got a 130/90 in mine its been in for more than a year and I run with the lights on all of the time.
Had no problems Vic
Good point Kenny - I was wondering about the switch handling that extra current...................easy enough to wire a relay into the circuit before the handlebar switch. I was interested to any effect the heat might have on the lens
				mark k
My bike has had a 130/90 in it since I got it about 2 1/2 years ago with no problems. Mine is an Aussie model with hard wired lights so it is always on. Cheers Mark
