what should i look for when buying a trx
leepy1
Post by leepy1 » Wed Jul 31, 2013 10:14 pm
Hi guys , new to the site and not very good on computer either :oops: , going to look at a trx this weekend and was wondering if i can get some advise on what to look for ? , been reading some posts and found that the oil level is a bit of and issue , how to check that is , been away from road bikes for a while , never looked at one of these bikes before but definitely having one as they look great , thanks lee
Silver
Re: what should i look for when buying a trx
Post by Silver » Thu Aug 01, 2013 7:43 am
You can only really check oil level immediately after a ride. Listen for rumbles and rattles from engine. Gearboxes can whine a bit in second gear (normal) otherwise normal things like bearings. Check frame welds for cracks.
Main thing is engine bottom end probs due to lack of oil. They do mostly use a bit of oil.
And obviously make sure its a blue one cos they are the fastest.
Dave
Red Rex
Post by Red Rex » Thu Aug 01, 2013 7:56 am
I'd say first impression counts for a lot too ... if the owner sounds pretty knowledgeable and the bike looks well looked after you should be OK. They are pretty solid bikes.
All as Dave says (except for his blatant lie about blue being faster ... RED is the way to go.
If you can't find a red one , buy a blue one and paint it :)
leepy1
Post by leepy1 » Thu Aug 01, 2013 6:33 pm
Thanks for advise , do the do a red and blue trx lol , would be best of both worlds ! , the bike i'm looking at is red and black , but have plans for some modification to the bike , when I get one that is , fingers crossed this weekend , again thanks for your help lee
Stu99
Post by Stu99 » Thu Aug 01, 2013 9:22 pm
G'day Lee,
Welcome.
Advice as above. The TRX is a solid bike but check all the normal things.
Ask the seller how they check the oil. If they hesitate or don't know, give that one a miss.
Also ask how much oil per 100km the bike uses. Any good, caring TRX owner will know. That calculation is routine for a TRX owner. If they don't know straight away, move on.
The TRX motor is a strong one and will rarely have issues unless the oil level has been neglected, hence the importance of those questions.
Oh and don't worry about them using a little oil, completely normal.
Good luck with your search.
leepy1
Post by leepy1 » Thu Aug 01, 2013 10:58 pm
Thanks stu for your help lee
andyaber
Post by andyaber » Fri Aug 02, 2013 10:08 am
Hi Lee
Looking at your ID and your name,
you could paint your TRX with 'little arrows'?
The red ones are quicker.
Cheers, Andy.
leepy1
Post by leepy1 » Fri Aug 02, 2013 8:10 pm
Lol , Andy don't think I will be doing that thanks , well hope it all pans out tomorrow keep you all posted , thanks lee
leepy1
Post by leepy1 » Sat Aug 03, 2013 8:07 pm
Hi all , I am now the proud owner of a red and black trx , owner was sound and checked oil after every ride he said , in the way you told me , gave bike a sort ride as I don't have a lid yet , had to use my trials pisspot lol , it's done 17500 miles and all seems ok , fingers crossed , going to change oil and then oil and filter in a few months time , what oil is the best for these bikes , sorry if i'm going over old ground for you all lee :D
Silver
Post by Silver » Sat Aug 03, 2013 8:12 pm
Motul 5100 every time for me.
Dave
leepy1
Post by leepy1 » Sat Aug 03, 2013 10:30 pm
Ok , thanks Dave , again !
Stu99
Post by Stu99 » Sun Aug 04, 2013 12:29 am
Agreed, Motul 5100, possibly none better, but can get expensive if you ride the bike a lot and it drinks a bit.
When I was knocking out 700 odd Km a week I used trusted but more cost effective oils.
Just remember, as long as it is a good quality oil of the correct grade, frequency of change is the most important thing.
If you feel like some reading there is an Oil questions section in the Tech/Trouble Questions Section. :D
Red Rex
Post by Red Rex » Sun Aug 04, 2013 7:21 am
Welcome to TRX-land.
So, you've got the oil question sorted.
Next will be , in no particular order ... what tyres? , where can I get a full-length belly pan / pillion seat cover / blue-spots / FCR41's ?, should I change the gearing ? .... (the list & fun goes on)
Whereabouts are you by the way ??
leepy1
Post by leepy1 » Sun Aug 04, 2013 8:27 am
In Rotherham , s York's , yeh there is a few bits I want to sort , same as any new bike and then buy some riding gear and get back into road riding ,which I think will take time
Red Rex
Post by Red Rex » Sun Aug 04, 2013 1:29 pm
As it happens ... I have a set of Akito jacket / jeans I was thinking of selling.
All in plain black leather , all in good condition (not brand new , but no scuffs that I can see) , usual body armour inserts.
Jacket is Size 44 , jeans are 36 waist.
I'm around 5'9" and weigh in at 12st-10lbs and they fit me.
I was thinking £75 + postage or sensible offer
.... interested ???
