Hello everyone
please can someone give their insight into a problem on my TRX? I started the hog up for a ride and noticed coolant leaking from the right side carb, so i took off the tank and had a jolly good poke around. Looking at similar topic already posted i think it must be the hose is old or perhaps theres a blockage inside the carb, any way can i get a longer hose and just simply connect up the 2 little exits on the main, large coolant hose and bypass the carbs altogether? also would i need to block off the carb coolant inlets?
All help gladly recieved but please keep it simple!
Jamie.
coolant leaking
Re: coolant leaking
Yep completing the coolant circuit with a length of silicon hose leads to little difference in how the bike will behave / run, unless you`re in a cold place (northern Europe).
In which case you `could` experience icing.
- Wombat
- Forum Marsupial
Re: coolant leaking
Yeah Jamie, mine used to do that. My mechanic at the time cured it by placing a ball bearing in the warming tube and solved the problem. Also meant that the coolant couldn't complete the carb circuit but after 7 or 8 years nothing's gone wrong so there you go
BTW they often leak either coolant or oil beneath the water pump too. Use search on this site to find more info
- jamie2476
Re: coolant leaking
Hello All,
many thanks for the info, great to have this forum for assistance.
Jamie.
Jamie.
- Wombat
- Forum Marsupial
Re: coolant leaking
And if you replace the carbs with FCRs those tubes become redundant
