Rear wheel sprocket carrier
To make life a little easier and choice of gearing, I'm looking at utilising another sprocket carrier with a different number of teeth to give me the option. Does anyone know if any sprocket carriers from other yamaha models would be the same as the TRX model as there's plenty online and cheap as just I can't find any up there for a TRX ... I just need one more so I can set up the 3rd rear wheel which has no carrier.
- fung
Re: Rear wheel sprocket carrier
cobba,
cross reference the oem part number on the U.S. parts sites.
add two zeros ?
subtract two ?
cant remember
post up what you find out eh
add two zeros ?
subtract two ?
cant remember
I would if I knew the OEM TRX part number ..
And can't access computer as its dead so working off my phone of late. How far can I go with std 110 link chain ??? As I'm hoping 17 43 cause I have a 39 and 40 on carriers already. I'll let you know if I track down the numbers tho
bubbaad
Don't know if it will 'stretch' to 43 but I'm on 17-42 on a 110 link chain.
- trixynut
I tried a 43 rear with standard 110 chain and it wasnt long enough.
Yzf750 carrier is the same.
Thanks trix ... Looks like a 95 up to 2000 yzf 600r also have the same part number .. So I'll try my luck and see how I go tracking one down.. I'll just have to sit down and work out the best combo so I can utilise the one chain length. But how much does two or three teeth on the rear move the axle forward???I'm running a 16/40 now and it's still pretty central and have a 39 on the other carrier so can i fit 16 / 39 -41-43 .on a 110 link chain...
- Kayla
YZF750, Thunderace, FZR600R (4JH), Thundercat (4TV) and the first Fazer 600 are all the same but you'll need a new bearing and spacer if you buy one from a Thunderace or YZF750
