TRX Restoration Project
Re: TRX Restoration Project
Post by alextrx850 » Sat Apr 07, 2012 10:25 pm
DANG..to those welds there Con Rod...does your welder mate own a FARM..? :lol:
Guess you cant look a gift horse..
Post by Con Rod » Sun Apr 08, 2012 12:13 am
LOL
yes they are not pretty, but they are strong and reasonably well hidden. Once they get a good think coat of paint they should not really be noticeable.
Post by fung » Sun Apr 08, 2012 12:39 am
out with the dremel and finish them off with a good two pack filler or paintable devcon.
:rr:
devlin
Post by devlin » Sun Apr 08, 2012 4:58 am
LOL at the reactions. Both of my brackets were breaking off so I just cut them clean and will make some stainless clamp on brackets.
Post by Con Rod » Sun Jul 08, 2012 2:58 pm
had a bit of free time tonight sitting around waiting for the baby to be born.....it has not been born yet, but in any case as I say I had some free time so I decided to sumarise this thread in a video
Phil Dekked
Post by Phil Dekked » Sun Jul 08, 2012 7:09 pm
Snap ! Had exactly the same happen to me. Though the exhaust didn`t fall off, just waved around in the breeze till my mate pointed it out on the highway!
Was worse than I thought as it had corroded the tube quite well! Also we found the other side was just as bad and about to snap as well. So left with some pretty large holes after cutting away the rot.
So my mate who`s a dab hand at welding helped me out with these ...
I haven`t got a finished picture on me right now ( I`m in europe and bike is in Aus!) but will dig one out when I get back. Looks great after a few coats of white!
.p.
Mostly Harmless....unless catering is shut.
Post by fung » Sun Jul 08, 2012 11:23 pm
I spy some fairly major bandaging on the left hands fingertips . . . . . .
#-o
good work matey.
:rr:
Phil Dekked
Post by Phil Dekked » Wed Jul 11, 2012 10:11 pm
Ha...good detective work sir!
Not mine though...my mate broke a finger inadvertantly doing some minor woodwork....he was wearing a 2 finger splint for a month or so...and then these bandages
It pissed him right off when it came to fiddly metalwork!
.p.
Post by Con Rod » Fri Jul 27, 2012 1:46 am
picture added for MV
M.V.
Post by M.V. » Fri Jul 27, 2012 2:08 am
Thank you sir!
Post by ekoja » Fri Jul 27, 2012 10:37 pm
Con Rod wrote:LOL
"The talk about welding reminds me of something Gordon Murray said before the McLaren F1 road car had been released.
A journo asked him whether it would be technically comparable to the then-new Ferrari F40.
'No', he smiled. 'Our people don't know how to weld that badly'.
A little bit late but there ya go.
Post by Con Rod » Mon Oct 29, 2012 12:11 pm
fung wrote:looks like things are progressing nicely! =D>
another plus is some shorter dogbones to raise the butt in conjuction with dropping the forks thru.
i went 20mm up at the back and down 15mm at the front.
seems to work nicely, using all the tyres and still turns in well, stable mid corner and i get good traction on the exit.
she hasn't got the heavy feel on the initial drop in to a corner the std height gave me.
:rr:
just looking back on this, I ended up following your advice and dropped 10mm on the front. Improved things dramatically from where they were. After a few months riding around I am now thinking I may, as suggested go with some shorter dogbones. Kayla's multi option adjuster thingys may be the go
Post by Con Rod » Mon Nov 19, 2012 8:05 am
rear brake reservoir was looking a bit tatty, but I didn't want to spend $80 on a Rizoma one to replace it:
but I came across something similar and cheaper on e-bay
http://www.ebay.com.au/itm/CNC-Billet-B ... 201wt_1163
Post by fung » Mon Nov 19, 2012 11:01 am
i bought an oem bottle from yamaha for $16 :)
Fung
:rr:
Post by Con Rod » Sat Jan 05, 2013 2:12 am
a bit of post Christmas shopping was on the cards so I have ordered race tech springs to weight and gold valve cartridge emulators from the US. Ordered through Amazon as the springs and valves came in at $260 delivered as opposed to $380 here in Oz.
Should get them around Jan 25
Any tips on the install, brazing etc? Did a search on the forum and it appears I need to drill out the compression holes to 8mm and braze up the adjustable rebound holes (at the top of the damper rod above the o-ring/seal bit) and remove the rebound adjuster and adjuster rods
