I have sourced some steel bar that is an interference fit with the tubing of the TRX frame. I am currently in the process of crafting a set of lugs to weld onto the frame for the bolt on subframe.
pics:
that's a piece cut to length, with this:
As you can see from the first pic I have started cutting out the hatched area. all will become apparent when I get finished. I am being hindered by my 15 month old son, I cant get in the garage when he's awake as he just wants to play all the time, and I cant operate my chop saw when he's in bed because I will wake him up!! the little bugger
anyways this is where its going to go:
imagine the bit sticking out chopped in half down the middle with a threaded hole through it. Dog was bored by this point.
Also fitted the R6 shock. if it performs as good as it looks I will be well chuffed!
Should have the engine back in over the weekend.
