I've asked for permission from our moderator/forum guru to post up this info on oil pressure switches
As i recently acquired sherlocks old TDM900
I have been in correspondence with a fellow on the Carpe forum, who makes oil pressure adapters that replace the banjo bolt on the crank feed end left side rear of the cylinders.
It uses a normally closed 0.5bar oil pressure switch and is quite an easy fit with a light straight into the instrument console.
Here is his email address
leehenty@gmail.com.
and here is a link to a step by step install guide on a TDM850
http://www.carpe-tdm.net/ipb/index.php?showtopic=17013
and some 900 pics
http://s923.photobucket.com/albums/ad73 ... ification/
Lee has told me to use a locally available Tridon TPS-048 oil pressure switch with an M10 x 1 thread, but he can go up or down 3mm in thread size depending on which switch you use.
I have two adapters on the way, one for the TRX and one for the 9er.
The TRX/TDM 850 adapters are 5 pound sterling plus post with the 9er bits needing a little more machining so a slightly higher price.
