Ok, I love my TRX but ...........
- WR450FGreg
Does anyone make an aftermarket seat that doesn't feel like the OEM Yamaha one, which in my opinion might as well have been made from bloody plywood?
I went for a 4 hour ride on the weekend.
I love the bike, but Yamaha really blew it with the seat, its bloody terrible!
Looks like Corbin don't do one, sadly.
Does anyone else?
Does anyone else?
'98 TRX850, '08 WR450F, '91 TZ250, '79 TZ350, '76 TZ250, '80 KX125.
Re: Ok, I love my TRX but ...........
ineresting topic..how bout a lambs wool cover....?
- Kevtrx849
- Moderator
OVER used to make a seat but that was many moons ago. I took some foam out of my seat and it transformed the bike. Made it into a saddle instead of a plank. Now i sit in the bike instead of on it. Check my photo at the top of the page. Easy enough to do as well.
( HENRY FORD )
( HENRY FORD )
- fung
cover made of sheepskin over the original . . . .or cycling knicks(for the anatomic support) under the jeans/leathers.
- Dav
Get it reupholstered with a gel insert or use a sheepskin cover or develop buns of steel
Actually cycling knicks work well, just don't have a crash and have your dirty secret revealed
- davamb
Lamby does it for me, and stand up off the seat every 10 mins or so. Don't leave it 'till it hurts, it's too late then.
Im not too bothered with the comfort from the seat itself, but really want to stop slideing around and have to hug the tank with my knees to stay in place...apart from useing velcro on my arse, i use a light wipe with clean engine oil,which gives the seat a vitamin pill and my bum stays planted....
My seat has done over 150,000 kays and still is 85 percent as good as new...same to the pillion seat...!
Used to ride all day on a Ducati 650, with a fibreglass seat/tank set up for British and European Twin raceing here in oz.
The seat only had 10mm of padding...i was just toooo busy
I also fing the TRX seat to be pretty comfy in all honesty but my hardened ass has been battered for years on seats that should have been referred to as rocks!
- ChrisH
i have used this company for most of my bikes, Medical grade Gel pads
http://www.caulfieldleather.co.uk/indexsports.html
Good link.
This, on their page, is very interesting:
http://www.caulfieldleather.co.uk/whatsnew2.html
LICS are another company who get good reviews too:
http://www.licsltd.co.uk/cgi-bin/esb_sh ... t=LICS_INT
Not cheap but then nothing good ever is!
- ricr378
I have a half hour commute daily which is fine but I took fungs advice on the cycle knicks for anything over a 1 hour ride. Its a cheap solution and works really well.
- WR450FGreg
I like this idea and I've actually thought about doing it to my WR450F due mainly to my short legs struggling to reach the ground!
What method did you use?
I've read about several, including freezing the seat then attacking it with a wood rasp while its hard! (This one actually sounds the best to me so far.)
kevtrx849,OVER used to make a seat but that was many moons ago. I took some foam out of my seat and it transformed the bike. Made it into a saddle instead of a plank. Now i sit in the bike instead of on it. Check my photo at the top of the page. Easy enough to do as well.
- Stankflapper
Hey Greg, dont feel too short mate, I ride a WR450 also and I am sure anyone who can touch the ground easily on one of those things needs to be 7'6" tallWR450FGreg wrote:.kevtrx849,OVER used to make a seat but that was many moons ago. I took some foam out of my seat and it transformed the bike. Made it into a saddle instead of a plank. Now i sit in the bike instead of on it. Check my photo at the top of the page. Easy enough to do as well.
- Kevtrx849
- Moderator
I used a belt sander attached to my bench grinder. Use a fine grit belt as it tends to grab if it's to aggressive. Electric carving knife would also work well ,as suggested. Never heard of the freezing method but can't see why not, worth a shot.WR450FGreg wrote:.
( HENRY FORD )
( HENRY FORD )
