My new TRX is trying to tell me something
Dav
Post by Dav » Mon Nov 14, 2011 8:00 am
but I'm not sure what...when the bike is warm the tacho cycles to 3 k, 1k and zero. It doesn't show up when the bike is first started or (for example) taken on a short test ride :roll: The bike runs beautifully, pulls strongly, runs clean...just the tacho goes el loco :D
Re: My new TRX is trying to tell me something
Post by fung » Mon Nov 14, 2011 8:04 am
hi dav.
search the forum for the manuel, look up the TPS adjustment.
try to reset it and see what happens.
:rr:
Dav
Post by Dav » Mon Nov 14, 2011 8:26 am
Thanks Fung...I'll do that. A search for "tacho error" led me to those tps threads. I'm too tired to make sense of it now...big day back and forth in the heat to first see then pick up the bike (public transport sucks). Beer o'clock now, super happy to be back on a trx 8)
Post by alextrx850 » Mon Nov 14, 2011 8:50 am
firstly thanks for adding your location in your info box and a couple of photos [ youre gonna have to look that how-to thread up as well]..as soon as beer oclock finishes.
Good to see another aussie
Post by trixynut » Mon Nov 14, 2011 6:15 pm
And you DONT want the TPS modification posts, you want one on how to adjust the TPS.
If you cant find anything, post here again and someone will talk you through it.
You'll need a star drive bit to loosen the bolts that hold the TPS in place.
Dav
Post by Dav » Tue Nov 15, 2011 3:58 am
Hmm, that was a ball ache...I've gone very slowly through the range of adjustment on the tps and get nothing but the 1k readout (though it does swing to 8K with the connector off). Maybe I need to remove the torx screws and see what happens i.e. extend the range of movement...in case the tps is mounted incorrectly on that square shaft doodad?
Post by Mincehead » Tue Nov 15, 2011 11:15 am
Could it have been pressure washed and you`re getting some kind of water ingress issues? :?
Dav
Post by Dav » Tue Nov 15, 2011 11:32 am
Hmmm...even though I didn't see the magic 4K diagnostic the tacho error signalling has disappeared...maybe something was loose. TPS is around the middle position and am happy to say the bike runs sweet, tacho works normally...result 8)
as an aside, I've beendoing some running around today (buying torx drivers, buying and installing new white bulbs and front pads) and have had more people chat about + admire the TRX in one day than I've had in 4 years of Versys ownership. Looks like my wife has got herself a new bike :)
Post by trixynut » Tue Nov 15, 2011 11:35 am
Amen to that buddy! :D
Post by Mincehead » Tue Nov 15, 2011 11:38 am
Well the Versys although a good all rounder, is hardly as good a looking bike as the TRX. I hope you and the new `woman` in your life will remain very happy for years to come.
The `keep her clean and treat her mean` atitude often adopted is best kept for the wife though. :wink: :lol:
Dav
Post by Dav » Fri Nov 18, 2011 1:00 pm
Uh-oh...glitch is back...will have another crack at adjusting it tomorrow but it looks like the tps is fried.
Local wreckers wanted $150 for a used one, waiting on a reply to see if a tdm one will suit ex ebay UK for $60 new.
Post by trixynut » Fri Nov 18, 2011 2:57 pm
Have you checked the three connections in the TPS thoroughly? They can get a bit loose and sometimes get water in.
Also, check youlve done up the stardrive adjustment screws tight as they can vibrate loose. I replaced mine with allen heads and loctited them once it was set up right.
Post by fung » Sat Nov 19, 2011 1:54 am
do you have access to a multimeter?
i'm sure someone on the forum knows what to look for; i.e. resistance, voltage etc.
:rr:
Dav
Post by Dav » Sat Nov 19, 2011 1:58 am
fung wrote:do you have access to a multimeter?
:rr:
Ha! Simultanoues posts! :D I checked all that but got wildly different readings...could be a toast tps, could be gorilla hands and cheap multimeter :lol:
Dav
Post by Dav » Sat Nov 19, 2011 2:00 am
Except mine didn't post...doh! Connectors dry and pristine...getting an 8K reading throught the range of adjustment now....grr. Anyone got a spare tps laying around?
