Here's the full list of parts, things fixed, repaired, restored, replaced, upgraded, re-built, polished, fabricated, etc...it's quite a list!
New Asashi Wave profile rear brake disc
New Asashi Wave profile front brake disc's (Gold Centre)
Workshop manual disc
Brembo rear brake pads
Front wheel bearing's
Rear wheel bearing's
Coerce Racing billet aluminium rearsets
Haymes Manual
K&N Oil & air filter
Rizoma grips & bar-ends
Throttle cable assembly - 4NX-26302-00
Clutch cable Assembly
Hose
clamps x6
Renthal rear sprocket (40t)
Supersprox front sprocket (17t)
DID 525VX GB-120 X-ring FB pro Street chain
Frame spools
Oxford LED indicators (x2 sets)
Oxford indicator spacers x 2 sets
Front brake lever - OEM
Rim Stripes - with TRX850 lettering
Replacement swingarm
New coolant recovery tank
Swingarm pivot oil seal, Swingarm pivot bearing's, washer
All Balls head bearing's
Blast, Weld & Powdercoat frame
General polishing (Brushing)
"New" OEM Seat & Fairing unit
"New" OEM rider & pillion seats.
"New" OEM indicators with clear lens.
Polished Headers
Powdercoated Wheels
Tyres - Dunlop Q2 - 120/60 x 17 / 160/60 x 17
Strip carburetor, clean, re-assembly
Ultrasonic cleaning of carburetor's
O ring Carbs x5
Shock fluid
Shock seal bump rubber & Spring spacer
Rear Shock Rebuild & Shock linkage re-build labour
Rear Brake Caliper re-build labour
Caliper Seal Kit
Polished (Brushed) Clutch cover
Grommets for tail light (Clark Rubber)
Paint ( Bunnings )
P47 Grommet's x4 (Fairing mount)
Screen - Solid Black / MRA
Plane bearing - crankshaft (brown) x4 - 3LD-11416-20
Plane Bearing - crankshaft (black) x2 - 3LD-11416-10
Plane Bearing - Connecting Rod x2) - 3LD-11656-10
Plane Bearing - ConnJ X2 - 3LD-11656-30
Cam Chain - 94591-40138
Piston ring set x2 - 3VD-11610-40
Piston (1.00mm overbore) x2 - 4NX-11638-00
400 Circlip PO12 X 2
Crankshaft and 1 connecting rod (Secondhand)
Gasket & Seal set
Fabrication - header pipes (41mm, 48mm, 50mm) & Modify GYTR FZ6 Cup race pipe
Ceramic coating - Headers
Exhaust Valve ( 5PS-12121-00) X 4
Intake Valve 2 ( 3LD-12112-02) X 4
Intake Valve (3LD-12111-02) X 2 @
Polished (Brushed) Rocker Cover & Remote Oil reservoir lid
Rebore & Hone
Face Head & Barrel
Machine seats
Port & Polish Cylinder Heads
NGK spark plugs x 2
Exhaust Bolt
Engine Paint x 2 cans
Exchange Shim
Belray Engine Oil / 10W-40 EXL
Coolant
Dissassemble Motor / Clean all parts
Beed blast all parts/ clean / mask / paint
Plastigauge all bearing surfaces /
Check piston to valve clearances & squish /
Install vlaves / re-install valves / Shim /
Modify Cam sprockets / dial in cams / Reassemble Motor /
Install motor
Dyno Tune
Engine Mount Spacer
Performance Cams - Ivan Tinghe ( Based on R1 Cam profile)
Dynojet Stage 3 Carbie Kit
K&N Air Filter
Clutch return spring...
It's quite a list....
And this doesnt include the many hours spent re-building the wiring loom, or the many hours cleaning stuff up, painting bits and pieces, etc...
And i still have to get the petrol tank repaired, and re-painted....not urgent, but a glaring omission!
