Thanks
Two lights in the one headlight
tyranrex90
Hello,ive just reciently got myself a trx
i was wondering how you would go about putting two headlights into the one?, i seen a few pictures of a trex's on this site that had it done.
Thanks
Thanks
- Killerwhale
Re: Two lights in the one headlight
Find/buy a FZR400RR headlight and bolt it on!tyranrex90 wrote:Hello,ive just reciently got myself a trxi was wondering how you would go about putting two headlights into the one?, i seen a few pictures of a trex's on this site that had it done.
Thanks
- Corners R Us
....but check out bulb availability before you do. I believe they are hard to come by...thebulbs that is!
Corners
Corners
Rubes
And bulbs can be expensive if you do find them. Also some talk of poor light projection from these. Shame as it looks good.
- Scotty
If you need globes / bulbs, my folks and brother run a specialist lighting store in Parramatta. Handy for those in Aus, but they ship overseas too!
http://www.pro-lamps.com/contact.php
Hope that might be of help!
Scotty.
Scotty.
1996 TRX850 Streetfighter (Daily Commuter)
2009 Husqvarna WR300 Enduro (Weekend Warrior)
Ride to survive, survive to ride.
- fung
hi scotty.Scotty wrote:If you need globes / bulbs, my folks and brother run a specialist lighting store in Parramatta. Handy for those in Aus, but they ship overseas too!
Scotty.
i went to the website to have a look as i just bought an FZR400 3TJ headlight from KEVTRX here in QLD.
can't find a parts list, so i will email them...but if you do happen to have a chat with mum,dad or bro will you please ask if they can supply me an upgrade bulb for this setup?
cheers mate
fung.
- SDN
I have seen a forum where they cut off the spot welds on a standard H4 halogen bulb and fit the FZR bulb backing plate, looked way too fiddly to me.
I am working on an adaptor which will allow me to fit standard H4 bulbs once I have cut off the backing plate and filed down the spot welds. Standard FZR bulbs are a ridiculous price £35 - 40 the pair and not easy to get.
My idea and I don't see why it wont work is to fabricate a backing plate copying the FZR bulb with the three locator prongs. Then solder this on to a short machined sleeve with a grub screw to grip the H4 bulb which has had it's backing plate cut off. just need a bit of machining time
They`re H7`s are they not?
No issues getting them as far as I know and why is anyone paying those sorts of prices? EvilBay do them for around a tenner if memory serves me correctly and even here they can be gleaned for 13 quid a pair:
http://www.autobulbsdirect.co.uk/h7-upg ... ter-bulbs/
I think there are now LED versions too, check out EvilBay.
Edit, ok I`m WRONG.
They are P30t-40`s / MH6R but they`re still on Evilbay:
http://cgi.ebay.co.uk/JAPANESE-IMPORT-H ... 0571242655
Can`t check if that link works from here, Ebay`s not allowed.
Ring make them, and sell them in trade packs, it might be worth someone contacting Ring stockists to see if a trade pack could be sourced and then members could buy some spares up cheap.
http://www.ringautomotive.co.uk/product ... ?prod=1763
If you click on the CAP TYPE in blue text you can see it`s the offset tangs that pose the problem. I think if it was me I would modify an H4 or 7 bulb base, cut off the tangs with tin snips and simply drill a small hole in the bulb base ring and the lamp holder for a small self tapping screw to stop the bulb rattling and twisting in it`s holder.
Edit, ok I`m WRONG.
- SDN
It is very difficult desoldering the base from the FZR bulb, I tried it on a scrap bulb, which is why I am going down the route of fabricating anew bulb holder H4 bulbs are easy to detach the base ring as they are spot welded on. Buggered if I want to pay £16.5 every time I blow a bulb.
The twin projector beam does look very good on the TRX
Hmmm I can save you a quid on a pair
http://www.phoenixautobulbs.co.uk/pr/pj ... lbs-Koito/
They might do a discount for buying in multiples of say ten.
I`ve emailed them asking just that!
These folk do trade packs too:
http://www.elta.co.uk/tradepacks.html
Hey SDN, they`re in your neck of the woods:
http://www.elta.co.uk/aboutus.html
I`m bored at work, it`s quiet so I`ve had time to find this BIBLE of automotive bulbs, probably all anyone might ever need to know:
http://www.lucas-electrical.cz/files/xc ... alogue.pdf
See page 64 for:
LLB0471 45/55W
LLB0472 65/55W
LLB0507 55/65W
These would be wattage upgrades on the bulbs we`re discussing here, which can be found on page 68. I`m sure the mounting of those three above is the same.
See page 64 for:
LLB0471 45/55W
LLB0472 65/55W
LLB0507 55/65W
Might of got a wee result here folks:
Hi G****
Many thanks for your note - We have plenty of stock of this type of bulb and can offer what I hope will be a happy solution!
How about a 10% discount for all of your forum members - just add a link to us in relation to Japanese Motorcycle Bulbs and ask them to use the discount code YAMFORUM at the checkout to gain their discount.
The code will work on ALL purchases and has no minimum value requirement.
Details of all the bulbs are here - http://www.phoenixautobulbs.co.uk/ct/ja ... car-bulbs/
In addition we do several motorcycle specific bulbs http://www.phoenixautobulbs.co.uk/sc/up ... ght-bulbs/
A final thought - we also have a number plate for sale (currently on retention) Y4MHA which is available if you want to offer it to any of your members, guide price around £5,000 GBP. Please ask if you want any additional information about the plate.
The discount code is active NOW and I look forward to hearing from you and your members in due course.
Regards
Simon
So, there you have it FZR400RR headlamp owners, better than nowt eh?
Should I reply to Simon telling him this forum accepts his companies offer folks, and Jak, can you organise a link of some sort on the forum to the company?
Hi G****
Regards
Simon
NWS870R
Thanks for that Mince - they're just round the corner from me as well!
We need Jak to agree it`s ok, then I can get back to Simon to get it all confirmed NWS.
I don`t think there will be any problems, just want it all to be above board.
NWS870R
No worries - i'll hang fire till i get the green light buddy
- Jak
Thanks for arranging this Mincy ... here's the answer
I tried really hard to find a green headlight piccy but this'll have to do!!!!!
