yzf750 rear wheel in standard trx swinger
Re: yzf750 rear wheel in standard trx swinger
I would rather not split it all up to be honest.
Mind, can any members confirm if the sprocket carrier and cush drive rubbers are the same on a YZF750 as the TRX?
I would compare them myself but it means getting the rear wheel out of the bike and it`s pi**ing down outside.If they are the same I could hang onto them, cush drive rubbers deteriorate over time so it would be good to have spares.
andyaber
I believe rubbers and carrier are the same but different bearing.
biker-nut-1986
ok mate
ill have a think but would rather just have the wheel
ill let you know in time mate
been a bad day and not really with it
- slow codger
- trixynut
Sprocket carrier and cush rubbers definitely the same on YF and TRX
That`s great cheers guys, you`re all twinkly little stars!
In that case how about 60 quids for the wheel in fetching pikey purple?
- boogie_de
Don't forget the rear brake, 'cause the original TRX rear brake holder wouldn't fit with the YZF axle. So you need the YZF rear brake including holder, too.
The One with the Terminator leg !!
andyaber
I've used the trx rear caliper on the yzf carrier.
- boogie_de
That's another possible solution.
I'll fit the rear brake from a R1, because i'll fit the front brake calipers from the R6.
