yzf750 rear wheel in standard trx swinger
biker-nut-1986
Post by biker-nut-1986 » Sun Nov 21, 2010 8:06 pm
will the yzf750 rear wheel fit into the standard trx swinger
long shot but worth an ask
Re: yzf750 rear wheel in standard trx swinger
Post by Mincehead » Sun Nov 21, 2010 8:10 pm
Yep, although you`ll have to use different bearings as the spindle is a different diameter.Kayla will be able to help with the bushes and such like.
I WAS going to do this myself but decided against it, still have a YZF750 rear wheel complete with new cush drive rubbers for sale actually. :wink:
biker-nut-1986
Post by biker-nut-1986 » Sun Nov 21, 2010 8:21 pm
brilliant
leads me to my next question
how much again ?
Post by trixynut » Sun Nov 21, 2010 8:40 pm
This is a relatively easy mod.
If you look on here somewhere, you'll find a 'how-to' that I posted up when i did it.
It includes the measurements for how much to turn down the wheel spacers.
Brake disc will line up fine with the TRX caliper, may just need a small washer on the caliper bolts but thats all.
Also, need to make sure you have a sprocket with a dished/recessed side to it (like the standard one is) so you can flip it over to make the chain run straight.
and bearings for the smaller axle diamenter of the TRX
Dave.
biker-nut-1986
Post by biker-nut-1986 » Sun Nov 21, 2010 8:48 pm
that was a very useful post trixy thank you very much
now to search for that 'how to' post
ive contacted kayla for the kit but might see if i can it myself with my new lathe that ive never learnt to use bahahahahahaha
Post by slow codger » Sun Nov 21, 2010 8:55 pm
:D As Trixy says, its not hard, everything lines up no problem, just remember to turn the sprocket around. You do have less choice getting replacement sprockets, but you can still get them.
Dave E.
biker-nut-1986
Post by biker-nut-1986 » Sun Nov 21, 2010 8:59 pm
thats brilliant
found the post trixy was explaining about
1 thing i dont understand fully
the sprocket is every sprocket got this lip ?
ill probably turn the sprocket carrier down so i can fit anything as standard !
Post by slow codger » Sun Nov 21, 2010 9:03 pm
:D Nope, you can shim the original out if you want, get bling anodised ones. but with the wider wheel, they wont line the chain up, needs the dished original turned around.
Post by Mincehead » Sun Nov 21, 2010 10:03 pm
biker-nut-1986 wrote:brilliant
how much again ?
The biggest problem is the postage/carriage, I could let the wheel, sprocket carrier and cush drive rubbers go for 75 quid but I`m not sure how much the carriage would be from Scotland to where, Brighton wasn`t it?
biker-nut-1986
Post by biker-nut-1986 » Sun Nov 21, 2010 10:11 pm
yea brighton bt ur down this way over xmas arnt you ?
not really interested in the cush drive sprocket carrier etc just the wheel can that be a better price or dont wanna split ?
andyaber
Post by andyaber » Sun Nov 21, 2010 10:16 pm
Hi, Sorry to take a sideways step, but i've just fitted a yzf swing arm and wheel, should i have turned the sprocket around?
Post by slow codger » Sun Nov 21, 2010 10:19 pm
:? You need to check the sideways alignment of thr chain, it needs to be as straight as it can so that no undue force is put upon the links!
andyaber
Post by andyaber » Sun Nov 21, 2010 10:21 pm
I only checked it by eye and it looked ok, will double check asap though.
Post by Mincehead » Sun Nov 21, 2010 10:29 pm
A good straight edge will help, just hold it square against the rear sprocket face and check to see if the chain follows the same `line`.
Alternatively a cheap `sunday market` laser pointer works well too.If it`s a steel bodied one a flat bar magnet will hold it against the rear sprocket face leaving your hands free. :wink:
Craft or modelling shops sell all kind of magnets.
biker-nut-1986
Post by biker-nut-1986 » Mon Nov 22, 2010 6:31 pm
biker-nut-1986 wrote:yea brighton bt ur down this way over xmas arnt you ?
sory to be aa pain but mince i did ask this
not being rude just need an answer before i buy one
