aftermarket oil lines ( braided )
biker-nut-1986
im looking to put an oil cooler on both my xtz750 and my trx project
i have noticed in this listing http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... MEWAX%3AIT
that hes fitted them
i did send him a message about a couple of things with no reply ( one of the things i asked was is he on here ) do we know wher i can get the connector plate that fits to the engine ?
any help will be brilliant
thanks
thanks
- trixynut
Re: aftermarket oil lines ( braided )
That is THE TRX owned (but now sold
) by honkdawillydahonk on this forum.
Only one I've ever seen with custom oil lines, and they are probably custom made by him: he's a clever chap!
Best to message Honk through the forum so he knows you're 'one of us'.
Goodridge or Earls can make up pretty much anything.
biker-nut-1986
thank you trixy
pm sent to honk and eagerly awaiting the reply
biker-nut-1986
reply received
if anyone else is interested
bsr aerotek will make em
Low pressure oil lines?
Again, you can make them yourself, ALL the raw materials are readily available:
http://www.earls.co.uk/earls/hose/
http://www.earls.co.uk/earls/adapters/
http://www.earls.co.uk/earls/hoseends/
http://www.earls.co.uk/earls/coolers/
But of course theres some elbow grease required.
biker-nut-1986
yea i get my lines direct from a company in america and they beat all the lines over here price and quality wise
i just need the connectors to the engine
already got my ducati 999 trapazoid cooler
The main adaptor on the top of the oil pump /crankcase housing could still be quite simply done with alloy. Some square bar in a four jaw chuck on a lathe and rough it out, then finish the exterior with hand files and a power drill for the two fixing holes.
Even without a lathe it would maybe be a couple of hours work for each with a junior hacksaw, pillar drill and files.
I had asked Honk who made up his oil lines, the relpy came back, "wasn`t cheap".
biker-nut-1986
id rather not make my own mount and just buy one
as i said i can make the lines just need to find the fixings
being expensive doesnt bother me
the front and rear end is going to cost me best part of £1000 if i can get em
the money for the lines will be down the back of the sofa
im now happy that the tdm got stolen cos i did want the trx more !
engine arrives next week then gets ripped apart and sent for tuning
and hopefully a hydraulic clutch conversion to make it smoother !
ill be ringin bsr aerotek tomorrow
Hydraulic clutch conversion?
I`ve found the TRX clutch to be very light and positive in operation, but then I`m used to British iron and Guzzi/Laverda MANS cluches.
