tank removal
roket52
tank removal
Post by roket52 » Sun Aug 15, 2010 4:01 am
Hi guys,
Im new to trx's and have just purchased a black 99 with 13500kms. LOve it and cant keep my hands off it. But to my question i was just after some simple help on removing the tank from anyone who has removed their tank before. How do you turn off the fuel when the tank tap does not have an off position?? Mine has a reserve, primary and on position.
Thanks its newb question I know!
Kevtrx849
Moderator
Re: tank removal
Post by Kevtrx849 » Sun Aug 15, 2010 8:29 am
I know the answer to this one :D It's a vacuum feed when in the on position which means that fuel will only flow when the engine is running. It will dribble a bit when you take the pipe off though. When you lift the tank you'll have to manouvre the vacuum lines as they become tight. Too easy.
( HENRY FORD )
roket52
Re: tank removal
Post by roket52 » Sun Aug 15, 2010 10:33 am
thanx kev.. the old vacuum fuel line trick yep i know that one cheers
Re: tank removal
Post by trixynut » Sun Aug 15, 2010 5:12 pm
....also, the TRX tank is designed to hinge backwards, so if you take out the two front bolts, one per side, and take off the fuel line from the tap and the breather hose that goes down through the swingarm, and just loosen the long bolt under the seat a little and it will hinge back.
M.V.
Re: tank removal
Post by M.V. » Mon Aug 16, 2010 1:40 am
trixynut wrote:....also, the TRX tank is designed to hinge backwards, so if you take out the two front bolts, one per side, and take off the fuel line from the tap and the breather hose that goes down through the swingarm, and just loosen the long bolt under the seat a little and it will hinge back.
Didn't know that... Seems pretty obvious now that you've mentioned it #-o
Thanks!
Re: tank removal
Post by Jak » Mon Aug 16, 2010 8:50 pm
Damn, you all beat me to it - this is one of those rare topics I could have posted something useful and helpful on #-o :lol: :lol: :lol:
xxr55
Re: tank removal
Post by xxr55 » Wed Aug 25, 2010 1:13 pm
G'day Guys,
This is my first post here. I've just removed my fuel tank for painting and so i've also removed the feul tap unit from the bottom of the tank. My Question is when I refit the fuel tap unit after painting will I need to use some sort of gasket glue or something between it and the tank or do you just screw the unit back on? Any wisdom would be much appreciated.
Re: tank removal
Post by trixynut » Wed Aug 25, 2010 3:35 pm
G'day XXR and welcome aboard.
If you look at the tap, there is a groove all round its edge which has a black rubber oval ring gasket it in. It may look a bit flat by now if the taps been on a while
This should just seal up fine when you put it back on, but what I did was took the rubber ring out, turned it over and put it back in the groove on the tap cos the other side was more roundy than the top side, so I thought it would seal better, if you get what I mean.
New rubber gaskets are available from Yamaha still if you need one.
Dave
xxr55
Re: tank removal
Post by xxr55 » Wed Aug 25, 2010 5:29 pm
Thanks for the quick reply Dave. Your explanation makes perfect sense.
Troy
blackrexy
Re: tank removal
Post by blackrexy » Wed Sep 30, 2015 5:07 am
The reason I found this forum. Thanks for the info! :D
Mav617
Re: tank removal
Post by Mav617 » Sat Jul 02, 2016 11:56 am
Will it hinge back far enough to change the air filter element?
GP100, Z200, RD250LC, CB250RS, RD250LC, GSXR400, RZ250LC, TZR250, FZR600, FZR600R, SZR660, VTR1000F, TRX850 x 2, MT-03, LCII 350 YPVS, VTR1000F
Rod.s
Re: tank removal
Post by Rod.s » Sat Jul 02, 2016 1:45 pm
Yep….
Mav617
Re: tank removal
Post by Mav617 » Mon Jul 04, 2016 5:06 pm
Cheers Rod :D
Re: tank removal
Post by dicky » Tue Jul 05, 2016 12:18 am
If you replace the fuel, vacuum and overflow hoses with some that are a bit longer and carefully route them, you can tip the tank back without having to unplug the hoses.
Makes for much easier tinkering.
