Chain convertion:What sprockets will fit?
M.V.
Post by M.V. » Tue Jul 06, 2010 3:40 am
Hi All, wanting to go to either a 520 or 530 chain, (mainly due to the cost of 525 chains) & I've done some searching, but I can't dig anything conrete up....
Anyway, which sprockets will work on the TRX?
Are there any that you can get working without extensive maching?
I'll be running 17/43 gearing, cos that's what I've got now & I like it.
Thanks in advance!
Re: Chain convertion:What sprockets will fit?
Post by Mincehead » Tue Jul 06, 2010 11:53 am
Sprocket manufacturers will just make up a rear from blanks in whatever you want, the rear is simple the front might be more problematic, I think the splines are the same as an R6 though.
In the UK we`re spoilt for choice with sprocket manufacturers but not sure about over there in the colonies. :wink:
If you take or send a front and rear standard sprocket to them they`ll manufacture whatever size and tooth number you require, it`s what the racers do to enable them to get gearing for all situations.
M.V.
Post by M.V. » Wed Jul 07, 2010 12:05 am
Roger that, I'll have to see if I can find any manufacturers... We used to have Chain Gang but I've heard they don't do motorcycle stuff anymore.
I was hoping to use off the shelf stuff, but oh well.
Post by Mincehead » Wed Jul 07, 2010 12:49 am
Apparently JT are in Australia, try contacting them for advice :wink: :
http://www.jtsprockets.com/42+M552e710fdb6.0.html
http://www.jtsprockets.com/63+M552e710fdb6.0.html
This gives you all the details you need, diameters, pcd`s, bolt holes, number and diameter of splines etc:
http://www.jtsprockets.com/52.0.html?&L ... id=2466&p=
49 tooth rear sprocket?
Wheelies R us!!!!!!! :shock:
M.V.
Post by M.V. » Wed Jul 07, 2010 6:16 am
Good point Mincehead, I have sent them an email.
They are our generic sprocket supplier over here, should have checked them first!
Kayla
Post by Kayla » Wed Jul 07, 2010 1:33 pm
M.V. wrote:Hi All, wanting to go to either a 520 or 530 chain, (mainly due to the cost of 525 chains) & I've done some searching, but I can't dig anything conrete up....
Thanks in advance!
B&C Express do a 520 conversion for the TRX, they just don't list it. Send them an email :D
M.V.
Post by M.V. » Thu Jul 08, 2010 12:09 am
Just heard back from JT, 530 only,
http://www.jtsprockets.com/61.0.html?&L ... =JTR859.43 for the rear
http://www.jtsprockets.com/61.0.html?&L ... =JTF580.17
for the front, should be able to cross reference other manufacturers from the list of models provided
devlin
Post by devlin » Thu Jul 08, 2010 12:24 am
Just looking at my setup. The front sprocket I just pulled from my bike has what looks like rubber molded to each side. Is this a stock original sprocket or after market?
Edit: I was poking around the JT site and found this page...
2nd Edit: But I just reread your first post and realised you don't want 525. As you were.
M.V.
Post by M.V. » Thu Jul 08, 2010 4:24 am
devlin wrote:Just looking at my setup. The front sprocket I just pulled from my bike has what looks like rubber molded to each side. Is this a stock original sprocket or after market?
Yes, that's the genuine one. Twice the price of a JT. Still haven't worked out what the rubber does though...
devlin
Post by devlin » Thu Jul 08, 2010 1:28 pm
The only thing I can think of is vibration damping as each roller strikes the sprocket. :scratch:
Post by Mincehead » Thu Jul 08, 2010 6:34 pm
Yep, that`s about it, a type of chain cushioning effect `of sorts`on the mesh with the sprocket.It might make transmission/chain noise slightly more quiet I suppose but not much else. :wink:
devlin
Post by devlin » Fri Jul 09, 2010 12:38 am
Mmmm, this recent tear down is starting to get out of control. Having inspected the drive train, I am also now up for a whole new set up. Starting to get the hook on the teeth. I wonder if the chain is original as well.
M.V.
Post by M.V. » Tue Jul 13, 2010 8:04 am
Chain Gang also do a 530 conversion,
Their front sprockets are $55ea, any size, & Rears are $139ea, any size.
$300 for JT Sprockets & RK chain or $500 for Chain Gang stuff...
Decisions, decisions...
Kayla
Post by Kayla » Tue Jul 13, 2010 8:25 am
M.V. wrote:Chain Gang also do a 530 conversion,
Bloody hell!
£300 for chain and sprockets? :shock: If you send me a PM and tell me what you want, I should be able to find some sprockets cheaper here and post it out to you, but you'll still need to find a chain over there to match.
schmiffee
Post by schmiffee » Tue Jul 13, 2010 1:47 pm
:D :D No No...that's $300 ($$$) not £300 :D
At the current exchange rate that would work out to around £160-£170
