PETROL TANK LOCK STUCK
Pulled the covers off the bike the other day to take it down the servo to put some air in the tyres and fuel in the tank as its been sitting in waiting the last 4mths and when i went to open the tank I could not turn the key...
I quickly rode home and tried graphite... to no availe..
and have just tried some wd40 /crc to try and free it up a little but still no luck..
Looking at the spare tank it still looks like you need to unlock it to actually unbolt the whole tank cap unit to remove it from the tank.. Any suggestions on how to attack the challenge ahead.
BigAl-TC
Re: PETROL TANK LOCK STUCK
Take it to your locksmith again, he should be able to sort it out if he is any good
Alan.
Alan.
- trixynut
You using the right key?
Yep, you need to have the cap unlocked to be able to remove it due to a security bolt underneath.
Sticking it in and wiggling it about a bit (cue fnar fnar comments....
) but be careful as the keys are made of cheese: very easy to twist or bend.
Other than that, locksmith, as already said.
My lock is always giving some reistance, my solution is to push it downwards with one hand, turning the key with the other.
- schmiffee
Well on my ignition it was partly worn and I found I had to push the key toward the top of the ignition and then it would turn perfectly...maybe a similar concept with your petrol cap
- Jak
trixynut wrote:You using the right key?![]()
My key's a bit dodgy too ... same as Hans, have to push down to turn it. Plus once I've started the bike I can take it out and shove it in my pocket
Red Rex
Cobba ...
Yeah, not a good feeling when you can't trust the key-lock combination. Guess you've already tried "sort of wiggling it about and moving it up and down at the same time" to try aqnd fool the lock into opening?
Jak ...
I have my key on a short lanyard (pinched from the missus' mobile phone cover) and loop it over a convenient clip on the headstock. Also clips to an inside pocket when I'm off the bike so I can't lose the key (I'm getting on a bit now and have to think about these things !!!
Jak ...
- Tarwetijger
That's a Yamaha is-it-a-bug-or-is-it-a-feature standard.Jak wrote: My key's a bit dodgy too ... same as Hans, have to push down to turn it.
Still have the spare key and both as bad or as good or as useless as each other
they where working fine just it has been sitting so oviously the bolt has seized in place... Tried turning the tank upside down to lube the bolt also so think when I get it sorted I'll go change to a screw cap style same as tank on trackbike.. Thanks heaps for your input...
- Jak
Good plan - that would have stopped me shutting it in under the pillion seat onceRed Rex wrote:Jak ...
I have my key on a short lanyard (pinched from the missus' mobile phone cover) and loop it over a convenient clip on the headstock. Also clips to an inside pocket when I'm off the bike so I can't lose the key (I'm getting on a bit now and have to think about these things !!!)
Well I've tried every thing
maybe its like the female anatomy if I dont hold my tongue right it just doent open up
- slow codger
You have to hold your tongue.......................as in with fingers or just shut up lol!!
- TonyDevil
mine does the sticking thing every so often, i take the key out, give it a whack with my gloved hand and then it worksHansJ wrote:My lock is always giving some reistance, my solution is to push it downwards with one hand, turning the key with the other.
TDM900 2003 - commuting tool
Z750 hardtail - project
MY FACE RACING came to the rescue and i just took the tank of my racebike while my tongue was occupied with a spectator...
trxster
Now that you have the tank off, how about setting it upside down, remove fuel tap, pour in 1x cup 2 stroke or engine oil, allow it to pool around the inside of the fuel cap for a cupla days and hopefully free up the latch etc.
Every month or so, spray some Lanogaurd on the rubber seal and the latch mechanism, works a treat
