B******D disc bolts
- AHTHUD
B******D disc bolts
Don't F******G believe it. I tried to remove the discs from the wheels last night and managed to sheer 3 on the front and 3 on the rear (I haven't even bothered to try the last ones on the back wheel yet). This was after giving them a good soak with WD40 and putting a bit of heat on them
. Now I dont know whether to try drilling them out, take the wheels to a local engineer (god knows how much that will cost, any ideas?) or bin them and buy something on fleabay! What do you think??
It's all good fun till the pain sets in!
- G Beale
Re: B******D disc bolts
Have the heads come off completely or just the holes rounded off ? Once the 6mm alan key starts to slip you have nothing to lose from hammering a bigger bit in the hole. Not alan key but either a T-45 torx bit or a multi spline M8 bit can't remember which, hammered all the way in. Big socket & ratchet on it & a sharp jolt from your palm or a rubber mallet. No use if the heads have snapped off obviously but I managed to free off 3 of the 6 rear bolts with rounded holes in this way without heat so got to be worth a try.
- trixynut
Nasty! They are made of cheese though.
The key is to have a really good fitting allen socket, tapped into the bolt, and try to tighten it a bit first before undoing it, and also give the bolt a little whack with a hammer first too, but thats no good now if they've snapped: stabledoor, horse, bolted etc..
When I snapped one, there was enough of a stub to grip with molegrips, after a good soak with 3-1 oil (I find its better than WD40) but maybe I was lucky.
Otherwise yep, its drills, heat etc.
- Tarwetijger
Aren't those secured with locktite? At least they are supposed to. So I'd go with the already mentioned things as good tools, tightening a bit first and a bit of heat.
- AHTHUD
All of them have sheared flush with the wheel
. I'm thinking of having a go at drilling them part way, winding in a tap and trying to wind them right through rather than out as the bolts seem to be corroded to bugger on the small section that protudes out the back of the wheel (if you get my drift). All of them moved a bit prior to sheering.
- Tarwetijger
Ouch! Can't you grind the corroded ends off?
Well, since they're flush, now you have to drill anyway...
- Silver
I use "snap-on" easyouts, but you really need to drill dead centre and use the biggest one you can without breaking through the thread.
Dave
Dave
- slow codger
rocket60
On another forum that I frequent the mechanical guru's warn against using stainless steel bolts on the brake discs because they work harden and snap.There was a lot of technical proof produced at the time to support this so I would be wary of using stainless steel bolts.
Vegetarian; ancient tribal slang for village idiot who can't hunt , fish or ride
- stormy
- Former Member
I had all 18 of mine shear when I took my discs off to have the wheels painted. I drilled all of mine out and re-tapped the holes again.AHTHUD wrote:All of them have sheared flush with the wheel![]()
Time consuming job, but a good result at the end.
Where are you based?
mike
1996 TRX850 ... gone away for a holiday
1997 TDM850 ... fully restored
1998 Ducati 748 ... it is very red
2000 Thunderace ... simply the best!
2008 Bandit 1250SA .... tis a bit dented now.... damn
- AHTHUD
All 18, Jeez that's a bitch. I tried drilling one of the bolts out and completely F***k it up (I was in a bad bad mood when I tried it so didn't give it enough thought) The only way to retrieve the wheel now would be to fill the bolt hole with ally weld and re drill and tap it. I live is Kent which is good as I'm only 20mins from Brands (was there last night doing an evening trackday on the TRX)stormy wrote:I had all 18 of mine shear when I took my discs off to have the wheels painted. I drilled all of mine out and re-tapped the holes again.AHTHUD wrote:All of them have sheared flush with the wheel![]()
mike
- stormy
- Former Member
I'm out of the country at the moment, but I think I may have a spare front wheel (with the discs removed already) in my attic. If you're stuck, lemme know.AHTHUD wrote: All 18, Jeez that's a bitch. I tried drilling one of the bolts out and completely F***k it up (I was in a bad bad mood when I tried it so didn't give it enough thought) The only way to retrieve the wheel now would be to fill the bolt hole with ally weld and re drill and tap it. I live is Kent which is good as I'm only 20mins from Brands (was there last night doing an evening trackday on the TRX)
I'm back on Tuesday, and I'll have a look in the attic when I get back.
mike
- AHTHUD
Cheers Mike. I bought a pair of powder coated wheel from Brad last week, but thanks anyway.stormy wrote:I'm out of the country at the moment, but I think I may have a spare front wheel (with the discs removed already) in my attic. If you're stuck, lemme know.AHTHUD wrote: All 18, Jeez that's a bitch. I tried drilling one of the bolts out and completely F***k it up (I was in a bad bad mood when I tried it so didn't give it enough thought) The only way to retrieve the wheel now would be to fill the bolt hole with ally weld and re drill and tap it. I live is Kent which is good as I'm only 20mins from Brands (was there last night doing an evening trackday on the TRX)
mike
- stormy
- Former Member
OK, no problem.AHTHUD wrote:Cheers Mike. I bought a pair of powder coated wheel from Brad last week, but thanks anyway.stormy wrote:I'm out of the country at the moment, but I think I may have a spare front wheel (with the discs removed already) in my attic. If you're stuck, lemme know.AHTHUD wrote: All 18, Jeez that's a bitch. I tried drilling one of the bolts out and completely F***k it up (I was in a bad bad mood when I tried it so didn't give it enough thought) The only way to retrieve the wheel now would be to fill the bolt hole with ally weld and re drill and tap it. I live is Kent which is good as I'm only 20mins from Brands (was there last night doing an evening trackday on the TRX)
mike
Mike.
