Front sprocket retainer
Re: Front sprocket retainer
Post by slow codger » Mon Mar 30, 2009 12:01 pm
:? Posted before re my predicament of losing the thread on the nut, I fortunately had a 1982 RM250 motor sitting in the garage the nut of which was the same thread size. (this the day before I was due to go out on it). That has aradite on it, its going no where now!
Rural Rat
Post by Rural Rat » Mon Mar 30, 2009 12:39 pm
Max wrote:
Rural Rat wrote:I am in the process of doing this now. Dumb question before I start. Is the drive sprocket nut LH or RH thread?
Regular RH thread.
Cheers Max, job done.
steve speed
Post by steve speed » Mon Mar 30, 2009 12:46 pm
just been in there to check and clean ,, and its not moved ,, nut , washer .all ok :D :D
Post by Mincehead » Mon Mar 30, 2009 12:49 pm
Good to know you keep your `nut washer` clean and tight. :wink: :P
steve speed
Post by steve speed » Mon Mar 30, 2009 12:50 pm
dont you ???? :lol: :lol: :lol:
Post by Mincehead » Mon Mar 30, 2009 1:04 pm
Nah,too tight is uncomfortable. :lol:
Janitor
Post by Max » Mon Mar 30, 2009 1:30 pm
Mincehead wrote:Nah,too tight is uncomfortable. :lol:
Says the man from "jockland"... :wink:
Post by Mincehead » Mon Mar 30, 2009 3:09 pm
Ah but I`m a sassenach,they don`t make kilts long enough for us,we would be exposing our`nuts` to the elements. :lol:
Now they might tighten up a bit it`s true but the discomfort would be unbearable even with Araldite,tab washers Loctite or grease!
Commando style and combats,the only way for comfort. :wink:
Wombat
Forum Marsupial
Post by Wombat » Tue Mar 31, 2009 6:27 am
The retaining washer has 2 flanges on it, so it's designed to be used twice. After that, throw it away. They're only $10AUD at any Yamaha dealer. I've gotta buy a new one when I renew the chain and sprockets around Easter time.
TonyDevil
Post by TonyDevil » Tue Mar 31, 2009 9:41 am
i bend the washer over in 3 places, i also use locktite 638 on splines of output shaft, between the sprocket, washer and nut surfaces and on the output shaft thread
i would only ever use OEM front sprockets and replace the washer tab and nut at EVERY retorque
its not worth saving a few quid when the end result writes your engine off
NB : an output shaft is £140, a gasket set is best part of £100, output shaft seal £10 plus oil etc
ie. thats over £250 in parts before you even start looking at labour
TDM900 2003 - commuting tool
Z750 hardtail - project
Post by Mincehead » Tue Mar 31, 2009 10:35 am
Hey TonyDevil,I call that the `Belt N Braces` approach. :wink:
But hey,if it`s what you need to feel safe,secure and happy and can be arsed to go to that trouble then why not?
As you say,a rebuild is a lot more expensive,and a leg(as your friends)PRICELESS.
