'01' vs '02' r1 forks
schmiffee
Post by schmiffee » Mon Mar 23, 2009 12:11 am
Just a quick question....is there any difference between '01' r 1 forks and '02' r1 forks?
Apparently the '01' forks are 'first generation' so I assume that the '02' forks would be second, or is that just referring to the bike overall and the forks are exactly the same. They are both 'blue-spot' forks and calipers so I would assume they would be the same item.
Thanks.
Kevtrx849
Moderator
Re: '01' vs '02' r1 forks
Post by Kevtrx849 » Mon Mar 23, 2009 3:43 am
G'day Schmiffee, 99-01 are 1st gen .02-03 are 2nd gen. 1st gen are slightly longer units and 2nd gen are full cartridge internals apparently. I'm sure someone else will be along to clarify shortly. :wink:
Congrats on the marriage btw. :wav: :loco:
( HENRY FORD )
schmiffee
Post by schmiffee » Mon Mar 23, 2009 4:26 am
So are the 1st Gen not cartridge? What's the advantage/disadvantage of each over the other??
