I'm about to complement my shortened rear dog bones by dropping the front forks thru the yokes a smidge, probably 10mm as a first adjustment
1. Do I need to take the fairing off to make life easier
2. Is it i best to have the bike on a paddock stand and support it with a plank under the pipes and lower it gently once everything slackened off
Or is it ok to just have it on a paddock stand
3. How tight are the yoke clamps done up
Will an allen key bit in a socket on a ratchet do the job
I spy one bar clamp,1 top yoke and 2 bottom yoke allen key bolts either side. Nothing else to undoe is there
Any pointers/pitfalls to avoid appreciated
I managed to generate a couple of hours me time today and fortuitously my m8 on his 08 GSXR-750 just happened to appear so we took a quick 45-mins around the local twisties to blow away the winter cob webs
! First time I've ridden the bike since buying it before Xmas and I've only just stopped smiling
but as usual you notice a variety of little jobs that need doing
....ah its good to be back in the land of fettle
! Also discovered that it had sod all petrol in it...realised when it coughed, spluttered and died on me
! Luckily putting it onto reserve allowed me to get to a petrol station and £14 latter the tank was brimmed again
Corners
