Frame Alignment Question?
- schmiffee
Just a few quick questions....I was looking at my replacement frame just today and realised that the front section is out of square. As in when looking at the section below where the tank would normally go from a bird's-eye-view, the left side of the frame angles outwards (top to bottom) whereas the oposite side does not (or no-where near as much)!! Has anyone else noticed this? Is this normal, or have I been sold a bent frame? And if this is normal, does anyone know the reason as to why this was done?
Just a couple of questions I was wondering....
- Kayla
Re: Frame Alignment Question?
I don't know about the TRX, but it's not unusual for frames have assymetrical engine mounts. The SZR660 has offset front mounts, biased to the left if I remember (looking down through the frame from above).
Have you tried measuring your frames up? Bottom of headstock to engine mounts and between the frame rails will give you an indication if the frame's poop or not.
edit- I'd go and have a quick look at mine but it's raining and I've just done me hair
- JL
Yes, it's normal. I freaked out when pulling my bike apart after a crash thinking I had really stuffed the frame, but it's meant to be like that. Not sure why though.
- slow codger
Just off on a tangent maybe
but I noticed the first few times I rode my trx when I bought it(especially in the rain while being a lttle more sensitive to the feel of whats happening under me plus hadn't ridden for a coupla years) it tended to want to pull itself back upright just a little when rolling on the throttle through a corner(only one way tho not the other,i think??? it may have been through left hand corners). Could this be to compensate for and throw from the motor and chaindrive on the left hand side???
Like you see a car motor twist when reving on it's engine mounts..
Even tho as such it's an east ,west motor sitting in the frame it's still been driven from the left and solid mounting so any torque(mmm is that the right word??)would manifest through the frame..
I'm always one to look out there at any possibilities and to keep an open mind....
Or is this just my sensitive nature
- Trixz
Yep it's true. Also noticeable when you mount crash pads, one short and one long one .. at first I was likeJL wrote:Yes, it's normal. I freaked out when pulling my bike apart after a crash thinking I had really stuffed the frame, but it's meant to be like that. Not sure why though.
- HolerTogni
Hi Gerben!
(Or did you mount the longer one on the right side
And like
Who can enlighten us with this?
Blurred greetings from Munich!
Hmmm, I thought the longer crash pad (on the left side) is because of the alternator protruding from the engine case more than the clutch does on the right sideTrixz wrote:
Yep it's true. Also noticeable when you mount crash pads, one short and one long one .. at first I was like![]()
And like
Wouldn't that mean that the shorter knob should be on the left side - but then it would make less sense with the more protruding alternatorschmiffee wrote: As in when looking at the section below where the tank would normally go from a bird's-eye-view, the left side of the frame angles outwards (top to bottom) whereas the oposite side does not (or no-where near as much)!!
- Trixz
EuhhhHolerTogni wrote:Hi Gerben!
Hmmm, I thought the longer crash pad (on the left side) is because of the alternator protruding from the engine case more than the clutch does on the right side![]()
(Or did you mount the longer one on the right side)
- Quan-Time
is it possible to take a bunch of pics, and some basic measurements and post them for future reference for anyone needing ?
would be a great help !!
- schmiffee
Quan-Time wrote...."is it possible to take a bunch of pics, and some basic measurements and post them for future reference for anyone needing ? would be a great help !!"
Yeah no probs...will do so in the next few days when I get some time.
GEEE
what planet was I on when I aired my thoughts..
Well dont ask, dont know. NOW KNOW also slight twist in forks (via tripple tree)possibly causing that lifting feeling thro corners on one side when first bought coupla yrs ago
