Manual Mikuni carburator BDST 38/2 // Backfires in exhaust
punica78
Post by punica78 » Tue Sep 09, 2008 7:59 pm
Hi all,
Since I'm having backfires in my exhaust I would like to check my carburator for any flaws which may cause these backfires. Therefore I'm looking for a manual of the Mikuni carburator BDST 38/2. I've surfed the internet and I found several Mikuni manuals for all kind of carburators but none for mine.
So I'm wondering is there a manual available for the BDST 38/2 and if so where can I get a copy?
5 May 2006: Zolder
2 September 2006: Folembray
"Fortitudo. Disciplina. Constantia. Patientia. Contemptus Mortis. Amor Gloriae. Amor Victoriae!"
Re: Manual Mikuni carburator BDST 38/2 // Backfires in exhaust
Post by Killerwhale » Tue Sep 09, 2008 8:06 pm
punica78 wrote:Hi all,
When fires in the exhaust it´s actually called front fires...back goes up the carbs...ANYWAY...
Isn´t the carbs pretty well covered in the servicemanual in the downloads??
Often it´s unburnt fuel wich ignite when going into warm headers wich having fresh air....you´ve checked for any leaks in the headers?? On the downside when trying to check what it is also a lean mixture in pilot will bang when closing throttle...
punica78
Post by punica78 » Tue Sep 09, 2008 8:14 pm
@Killerwhale: your remark on bangs when closing throttle is spot on. Any tips on how I best can check the lean mixture in the pilot? I've already checked most logical parts for leaks where false air could enter the engine like holes in the downpipes.
On the side: so frontfires is when I have bangs in my exhaust and when I would have had backfires I should have had bangs in my carburator?
5 May 2006: Zolder
Post by Killerwhale » Tue Sep 09, 2008 8:22 pm
punica78 wrote:@Killerwhale:
Most people call all bangs backfires so don´t hang up on that.... 8)
I would have tried bigger pilot jets...but as i have a dude with reasonable prices on dyno runs i would actually have it up on the dyno measuring the air/fuel ratio.
But....my bike was fat as hell on the fuelscrews so i went down a size in pilotjets and it started popping as hell on close throttle so i adjusted that with the fuelscrews and then it was spot on with no bangs....mind you i have FCR´s...
Post by phuk72 » Tue Sep 09, 2008 8:50 pm
If its poppimg and banging on the over run then it's probably too rich
Has your fuel comsumption increased ? Worn emulsion tubes?
try lifting the needle a notch and see if that helps
steve speed
Re: Manual Mikuni carburetor BDST 38/2 // Backfires in exhaust
Post by steve speed » Tue Sep 09, 2008 8:54 pm
wont lifting the needle make it richer ?? :? :? :? :?
punica78
Post by punica78 » Tue Sep 09, 2008 8:58 pm
@Phuk72: Fuel consumption has not increased. Currently I can do 100km with 6,5 liters of fuel. I was also thinking that problem may lay in the emulsion tubes or the gasneedles but I don't have any reference point on how a healthy emulsion or gasneedle should look like. Hence my search for the manual.
5 May 2006: Zolder
Post by Killerwhale » Tue Sep 09, 2008 9:00 pm
punica78 wrote:@Phuk72: Fuel consumption has not increased. Currently I can 100km with 6,5 liters of fuel. I was also thinking that problem may lay in the emulsion tubes or the gasneedles but I don't have any reference point on how a healthy emulsion or gasneedle should look like. Hence my search for the manual.
Pop at throttle off would tell me that it´s lean anyway...
punica78
Post by punica78 » Tue Sep 09, 2008 9:02 pm
So the first thing that I should do is correct the mixture by lifting up the needle a notch?
5 May 2006: Zolder
Post by Killerwhale » Tue Sep 09, 2008 9:18 pm
I would try the fuelscrews at first....no i lie....i would do the dyno at first...
But screw them in recording the turns....if at 1,5 turn out....try 2 turns....if it fix problem good.....if not and still pops go leaner pilot and go back on the fuel screw. If under 1 turn and over 2 turns you should check the pilot...
Post by phuk72 » Tue Sep 09, 2008 9:25 pm
steve speed wrote:wont lifting the needle make it richer ?? :? :? :? :?
good point well made :oops:
Post by HansJ » Tue Sep 09, 2008 9:37 pm
Killerwhale wrote: I would try the fuelscrews at first....no i lie....i would do the dyno at first...
Might help, but remember the screws are for small openings, needles are for middle and mains for full. Check all vacuum hoses also!
