Hello..........
biffo
Hello..........
Post by biffo » Thu Aug 07, 2008 9:29 pm
Hello, just signed up to the forum
hope someone can help me with this:
i went to buy a TRX 850, cosmetically the bike was in a nice clean condition, but something bothered me, at the join between the head and the cylinder there was a thin line of discolouration all the way around the joint, but only on the left cylinder, i could not work out what this was i.e. oil, grease, or a disintegrating gasket.
So i revved the bike and at mid range there was a dark colouration from the exhaust not a lot, just a thin viel of dark grey.
from the exhaust.
can anyone shed some light as to what this may be.
Thanks in advance.
TonyDevil
Re: Hello..........
Post by TonyDevil » Fri Aug 08, 2008 10:46 am
did you check the coolant for oil?
my guess is take the radiator cap off and you'll see a milky covering on the underside of the cap
if so walk away, its fecked
TDM900 2003 - commuting tool
Z750 hardtail - project
idl1975
Re: Hello..........
Post by idl1975 » Fri Aug 08, 2008 2:52 pm
If the smoke was from both exhausts, that may be perfectly normal. Most (many?) TRXs burn oil. Mine has done about 25,000 miles so far, and I've seen similar SMALL amounts of in the past. It still hasn't blown up, so that in and of itself is probably nothing to worry about.
Not clear what the discolouration could be, except to say the previous advice is worth following. Could just be the head came off for valve clearances and wasn't torqued down correctly - at a guess. But why take the chance? TRXs are easy to find used, so go for another one.
biffo wrote:Hello, just signed up to the forum
from the exhaust.
Thanks in advance.
'04 Aprilia Tuono Fighter
'00 Scooby Sport Wagon
'76 TY250.
biffo
Re: Hello..........
Post by biffo » Fri Aug 08, 2008 5:44 pm
Thank you both for the response to my question,much appreciated.
I think i will take your advice and walk away.
should you know any one selling a trx in very good condition iam in the market for one .
thanks again
Biffo
Re: Hello..........
Post by slow codger » Fri Aug 08, 2008 8:24 pm
:D You don't say where you are, but check your local E-bay.
Dave E.
