Anyway - here's the graph,
Dunno if you can see the numbers, but it made 82 bhp at the wheel, and I asked him to limit at 9000 rpm, but looking at the charts the HP figure started to tail off before then anyway.
It was only supposed to be a suck-it-and-see run, so didn't expect a full tune, but the guy in the know said that it was quite rich at idle and WOT, but spot on in the cruising range. Idle can be sorted with a tweak on the air-screw, but from what he suggested regarding WOT, I could probably get the mix right by going down a jet size, but if I do that will I be able to maintain the mid-range by simply lifting the needle, or will I have to mess around with needle profiles as well..??
I can't remember what the needle codes were, but I have a chart to decipher the numbers if needs be, and as far as I remember the mains were 155s. Carbs are FCR 39s, full Akra exhaust, TPS mod.
Interesting morning though ..
G
I will go back to the dyno at some point to smooth it out but for now I am happy with how it feels if I were you I would drop the m/j try it then try the needle pos yourself, if it feels better bring it back to the same dyno and give it another go just to check your a/f
