Discbolts
- Killerwhale
Discbolts
Well, there are no chance i can get a front bolt off ATM...so question...
Are the front and rear discbolts the same....M8 30mm??
Danke!
....and wouldn´t i be good with 20mm.
Danke!
- phuk72
Re: Discbolts
Yes they are the same IIRC
Try smashing in a star (torx) bit or using an allen key and then, using a punch, knock the head into the key to create a 'new' hole
- Omegaman
Re: Discbolts
i replaced all mine recently and they are made of a very soft cheese .........
i havent been that delicate at doing something since i played operation at the tender age of 8
Its all fun and games till someone gets poked in the eye.
- Killerwhale
Re: Discbolts
Well, i struggled with the rear a year ago but that´s fine and the front will be on there for a while longer....i just wanted to prepare with a set of TI bolts...Omegaman wrote:i replaced all mine recently and they are made of a very soft cheese .........
Cheers guy´s!
- Trixz
Re: Discbolts
Front and back are thesame! (as said).
Did mine last year and needed a wrench to get them out
Sadly I've put them back in with blue locktight... don't know how much effort it will cost me in a few months to get them out again
- Killerwhale
Re: Discbolts
Just take a soldering iron on the bolts and any loctite will loosen up!!Trixz wrote:Front and back are thesame! (as said).
Did mine last year and needed a wrench to get them outSadly I've put them back in with blue locktight... don't know how much effort it will cost me in a few months to get them out again
...in case you have a "kitchen torch" wich is used to make Crème brûlé....then your set as well!!
- Trixz
Re: Discbolts
Why didn't I think of thatKillerwhale wrote:Just take a soldering iron on the bolts and any loctite will loosen up!!Trixz wrote:Front and back are thesame! (as said).
Gerben![]()
Thanx
- slow codger
Re: Discbolts
If you can replace with a decent bolts then do so, then locktite them in.
Steve
Re: Discbolts
I had a go at removing a rear disc recently, did the usual tighten a touch 1st then undo, got 2 turns then off came it's head
so thought sod it took it to a mate who does head skimming/reboring/engine rebuilds etc to drill out the stud and asked him to remove the rest while he was at it
turned out to be a pig of a wheel cos he ended up snapping off the rest of em!! so now the disc will be held on by 2 helicoils and 4 other thread insert thingys
Red 97' Rex + Black/bronze '53 Falco
- slow codger
Re: Discbolts
- slow codger
Steve
Re: Discbolts
Was the disc fubar before you attacked it though?slow codger wrote:The disc that is, not the wheel.
if not what the hell did you use!?
- slow codger
Re: Discbolts
Steve
Re: Discbolts
Holy carp these disc bolts are ££'s
Thought id better put some new ones in since i went to the expense of coated wheels, bloody £28 for 18
New Diablo rubbery bits £165
powder coated wheels £100
new shiny disc bolts £28
the ride is priceless and puts a smile on yer clock everyday unlike mastercard
- Omegaman
Re: Discbolts
i paid £22 for the full set of front and rear from yamaha
would have prefered stainless ones or titanium
