holes in the engine
666mph
holes in the engine
Post by 666mph » Sun Apr 27, 2008 1:38 pm
Ok, i've got a couple of small holes that maybe some screws / bolts have come out of. One is on the left hand side (as you sit on the bike) of the engine/head, the other is on the right hand side (as you sit on the bike) on the sump.
The one in the sump looks like it once had a bolt, though it dosn't seem to be a problem - no oil is coming out. The one on the head - is this normal, is it there from when the head was cast?
here's the pics -
Re: holes in the engine
Post by youngy » Sun Apr 27, 2008 3:17 pm
they are both as they should be.
the one on the head is a drain hole. there is a drilling between the two sparkplug holes leading to this hole, to drain any water that collects around the plugs.
no idea what the one in the oil pan is for.
666mph
Post by 666mph » Sun Apr 27, 2008 5:26 pm
Cheers Youngy, thank for taking a look.
wicky
Post by wicky » Wed May 07, 2008 10:08 pm
youngy wrote:they are both as they should be.
Hi it's fer the fitting of an engine bashplate/sump guard as fitted to TDM's.
