What does a TRX engine sound like ?
jake
Does it have a ticking noise, can you hear the cams, etc ... my one has been rebuild .. AGAIN ... and it pulls really hard, engine brakes hard (so compression is good) but it still has this constant ticking noise. No one has a TRX that i know, so i can compare it.
Also, when im slowing down almost to a dead stop it starts to pop, ive got a full exaust, i dont know if thats normal.
Cheers guys
Cheers guys
- Killerwhale
Re: What does a TRX engine sound like ?
I thought it was broke first time i heard it....it´s a tractor!! It ticks rattles etc. etc.jake wrote:Does it have a ticking noise, can you hear the cams, etc ... my one has been rebuild .. AGAIN ... and it pulls really hard, engine brakes hard (so compression is good) but it still has this constant ticking noise. No one has a TRX that i know, so i can compare it.
Cheers guys
Is it the motor wich pops when going to a halt?
I had small popping jerks when almost at a stop a while back, fixed it with a new chain and sprockets....
jake
Well that makes me a lot better Killerwhale, because like i said, it pulls hard, stops well, does everything its supposed to, has so much power thru the entire rev range. But still rattles like a tractor.
99 TRX850
02 GSX-R600
02 Hyosung Comet 250
02 GSX-R600
- Killerwhale
Well, the 1098R kinda sound as if broke to (for other reasons but...) but runs quite nice...jake wrote:Well that makes me a lot better Killerwhale, because like i said, it pulls hard, stops well, does everything its supposed to, has so much power thru the entire rev range. But still rattles like a tractor.
- slow codger
Dave E.
- steve speed
the backfiring ,,i also believe there could be a problem with the valve in the carb iam not sure what its called but its behind the white plastic disk held on with two screws on the side of the carb
- Quan-Time
http://www.users.on.net/~auska/bike/tankcam1.aVi
dodgy as hell, but it MIGHT give you an idea of what they sound like..
Reason: to make the link work ;-)
