not turning over
brush
twolfe
I'm with Kev, The battery is shot.It may look ok, but once you put the starter load on it you will find it is dropping to about 8 or 9 volts or less.New battery problem solved.Trying to jump it off another battery may not work if the original battery is RS.If you can borrow a battery off someone else it probably would be a better indication.Like brush says clean the terminals for good measure.
bernardo
- Quan-Time
+1 battery.
Battery was charged over night, charger said it was 100%, put it in, turned once, click click click.... WTF ?
It had volts, but no AMPs behind it.. Luckily the charger has a jump started from the house mains. So i connected it up, started the bike 1st go (about 4 cycles).
New battery, fixed the problem..
- slow codger
- Jak
I think what threw you is that I was the one to suggest itwannicle wrote:im sensing a trend here, and am big enough to realise when someone knows more than me!
