overheating..
TWISTEDTWIN
overheating..
Post by TWISTEDTWIN » Sat Oct 20, 2007 10:41 am
Hi
The other day I ended up in a completely congested area of London with the trx (most of it is..you might say!!),anyway before I knew it the temperature gauge went up to 100 degrees...scary!
I haven't had the bike for that long, so i was wondering if this is quite common.
There is plenty of coolant into the rad, and at about 100degrees I couldn't detect the cooling fan kicking in, isn't it supposed to start working before boiling point?!!
Looking forward to hear from you doc's!
In the stables...:
TRX
KTM380SX
BMW G/S
BMW Cafe Racer
sherlock
Post by sherlock » Sat Oct 20, 2007 12:22 pm
Twisted,
The fan kicks in at around 106, from memory, as water under pressure has a higher boiling point. When the fan does kick in you'll wonder what the hell happened.
We've all wondered and then experienced this at some time.
elementary my dear.....
Post by trixynut » Sat Oct 20, 2007 6:49 pm
Mate,
The fan hardly ever comes on! Use search on 'termerature' or something similar on the forum: been discussed a few times before.
Dave
Post by Jak » Sun Oct 21, 2007 12:42 am
trixynut wrote:Mate,
Dave
.... probably get more results if you do a search for "temperature" :twisted:
Janitor
Post by Max » Sun Oct 21, 2007 12:48 am
Also, I don't think the little numbers on that guage are very accurate...
bernardo
Post by bernardo » Mon Oct 22, 2007 1:11 pm
I commute across London everyday and it runs over 100 on a regular basis, fan kicks in (106 sounds right) and out (95ish) all the time in heavy traffic. It's very quiet and doesn't noticably draw current so you wouldn't know it's on except for the temp drop and the blast of hot air on your legs.
Cools down real quick once you get moving so I wouldn't sweat it.
Post by ekoja » Mon Oct 22, 2007 1:31 pm
This is a response to an e-mail to Yamaha Australia
Operating temperature of the fan is from 105 deg +or - 3 deg down to 98 deg.
TWISTEDTWIN
Post by TWISTEDTWIN » Wed Oct 24, 2007 9:53 pm
Thanks to everyone for the various tips!! :D
In the stables...:
TRX
KTM380SX
BMW G/S
BMW Cafe Racer
