ignitech
kev c
Re: ignitech
Ivefound some tiny numbers but i still think its not a job for anyone not good at electrics certainly not plug and play
- HolerTogni
Re: ignitech
Hi kev c!
I have an Ignitech unit in my Race-TRiXie and could look how the plug is wired.
But this can (will) take a few days cos Race-TRiXie is a few streets away from home and I'll have a few kinda busy days next week.
Asking for patience - greets from Munich!
kev c
Re: ignitech
Thanks i will try to sort it out first but will call you in if i get stuck
- dicky
Re: ignitech
You can find the wiring instructions on the Ignitech web site here
Refer to the wiring diagrams in the service manual to see the TRX side.
Here is the page as an image
You can get the entire manual in PDF form from the Downloads section of this site.
kev c
Re: ignitech
Thanks ive managed to find very tiny numbers on the plug so should be ok now
kev c
Re: ignitech
Ive still not sorted it There are two green wires on the bike one going to the tps neither marked on the instruction sheet
- dicky
Re: ignitech
I've drawn the pinouts of the three connectors, the big Ignitech one and the two TRX ones.
Colour codes are as per the TRX wiring schematic. V is violet but is not used on the TRX.
edit: I have replaced the original pic as it was too confusing even for me. I hope I got it right this time.
You need to make a cable that does the following:
The big connector plugs into the TCIP4
The other two connectors plug into the TRX wiring loom.
- Tarwetijger
- dicky
Re: ignitech
There is green wire (Lg) in the six pin plug to the ignition box, and also in the plug to the starter cut-out relay, neither of which connect to the Ignitech.
I know others swear by the Haynes manual, but I only swear at it.
- Tarwetijger
- dicky
Re: ignitech
Haven't you answered your own question?I know some call them the great book of lies, but why?
How many green wires are there in the Hayes manual?
- Tarwetijger
kev c
Re: ignitech
Thanks all ive not replied yet cos i was on hol overseas can get stuck in now
