Test ride
kenbev
Test ride
Post by kenbev » Sat Dec 05, 2020 1:48 am
Took my TRX recently restored for its first test ride to-day and all went well but I found it to be very highly geared. My question is does anybody know what the perfect sprocket size would be to stop the snatch between gears. Thanks. Kenbev. :?: :?:
HolerTogni
Re: Test ride
Post by HolerTogni » Sat Dec 05, 2020 11:58 am
Hi kenbev!
Not really sure what you mean with "snatch" ...
For me and many others a shorter gearing of 17 / 42 (39 is the original at the rear) is good for compensating the long first gear.
Shortened greets from Munich!
kenbev
Re: Test ride
Post by kenbev » Sun Dec 06, 2020 12:45 am
Thanks for the reply. Long time since I have ridden a TRX and had forgotten about the long first gear. I have a 42 tooth rear sprocket to try and see if that makes it a bit better. Thanks and keep well. Kenbev. =D> =D>
