ecu question
ecu question
Well ive a 1996 trx with a 4tx tdm engine fitted. But the ecu seems to be from the original trx. Now the bike does not pull well. When you give it throttle she seems to hesitate and then take off.Has done this since I bought it. Would the ecu cause this? or should the ecu be compatible? The bike starts first pick and, if you take your time ,gets up a fine head of steam
- Rod.s
Re: ecu question
Hoping not to sound dictatorial, All the issues you have describe will be service related and majority from the carbs.
It's a 22 year old bike and was most likely serviced well for the first few years. If the bike has spent it's life in Ireland then as you know the weather can be harsh on man and machine.
The carbs on these work well if treated to some love and care and an occasional service. You don't need to completely strip them (unless snowbound for a few months ) just clean and replace the emission tube and needle, the jets will last twice as long and if the filter is intact (fitted to the inlet of the T piece between the carbs) then a lot longer, replace the gaskets and using a quality balance, balance the carbs, remembering that if you've adjusted the valves or replace the exhaust/mufflers then that will effect the balance.
Replace the right hand side white circular plastic air cut off cover as the bike sits on the side stand to the left this plastic cover gets the sunlight, it is effected by UV light and gets micro cracks (and can bend ) resulting in a vacuum loss and poor running at low RPM, the one on the left hand carb lasts a lot longer. The choke mech has a tendency to stick slightly open, give the cable and mech a good lube.
The needle clip position is variable and can be quite different from bike to bike, I run a K&N filter and find I need to drop the needle one clip and it still runs a little rich, I'm looking at changing the main jets to help with the over fuelling, yet other bikes run beautifully set to standard, make sure the little centralising washer is fitted and if not make one and fit it, see link.
http://www.trx850.com/phpBB_forum/viewt ... ic#p119873
There is a foam collar under the tank that keeps the "air" forced into the intake for the air box, don't remove it just make sure that it's intact and not being sucked into the airbox inlet, they do have a tendency to come loose (old glue) and can restrict the air flow.
The ignition is fine on these, but a little soft, you will notice the Ignictec Ign is a great upgrade and will change the feel and sound of the bike plus it improves the low to mid range power delivery, the ignition on modern bikes either works or it doesn't, as a mech mate of mine said, "all ignitions issues are found to be in the carburettors". The leads are also most likely on their last legs, replace them, (see link)
http://www.trx850.com/phpBB_forum/viewt ... ds#p119623
Re: ecu question
Thanks for replies. I now know what im doing for the winter months
- Rod.s
Re: ecu question
Just another note, if you don't have a rear hugger fitted, get some filter foam and cut it up and fit into the carb breathers that go down the left hand side of the carbs. They are the long black rubber hoses that have a strange tube filter fitted at the end and end up under the frame cross tube. The factory fitted a corse filter and it isn't very good at keeping road crap and tyre rubber out of the carbs. As this feeds into the slide diaphragm area which has the slow running and choke "extra" air jet it can get full of crap and effect the slow runninggrumpy1 wrote:Thanks for replies. I now know what im doing for the winter months
http://www.trx850.com/phpBB_forum/viewt ... f=5&t=8041
http://www.trx850.com/phpBB_forum/viewt ... f=5&t=8628
