Fitting R1 Fork Extenders
Post by davamb » Sat Mar 03, 2018 12:34 pm
So I bought the R1 extenda kit:
http://extremecreations.com.au/yamaha-fork-extensions
but how the hell do you get the damper rod retaining screw undone from the bottom of the forks???
Re: Fitting R1 Fork Extenders
Post by Mincehead » Sat Mar 03, 2018 1:45 pm
Rattle gun is the normal way! :wink:
Post by davamb » Sun Mar 04, 2018 5:58 am
Cheers Mince, but boy not understand. I can turn the screw, but it just turns the damper tube inside the forkleg. Unsure how a rattle gun will help.
Post by davamb » Sun Mar 04, 2018 8:01 am
...but that didn't stop me from trying it! Should use my air tools more often. Just have to re-assemble everything now.
HolerTogni
Post by HolerTogni » Sun Mar 04, 2018 8:36 pm
:lol: Another proof that acceleration is what really counts!
... and that inertia sometimes is helpful :roll: :wink:
I'm also always glad that the the laws of physics work without me having to understand them (says a mechanical engineer :oops: :roll: )
Physical greetings from Munich!
Post by davamb » Sun Mar 04, 2018 10:46 pm
HolerTogni wrote:I'm also always glad that the the laws of physics work without me having to understand them (says a mechanical engineer :oops: :roll: )
Ahh, well then. That lets me off the hook as I'm only an electronics engineer!
Post by coxylaad » Thu Mar 08, 2018 9:22 am
Thats an interesting solution, do they tell you what the new oil levels and air gaps should be?
Post by davamb » Thu Mar 08, 2018 11:24 am
Hey Coxy,
I think a bit of experimentation will be required, the instructions supplied only say to replace the same (or amount of) oil as removed. And if "using the oil height method, add the fork extension length to the standard measurement". I'll start with replacing the same amount and then check that for height. If a large discrepancy, then I will think and investigate. After that, test ride and evaluate, adjust and iterate.
Post by davamb » Sat Mar 24, 2018 6:49 am
Well I didn't plan for this - the hydraulic lines aren't long enough to place the calipers in the desired position. I'll drop the forks through the triple clamps 'till they do fit and see what I end up with.
Post by davamb » Sat Mar 24, 2018 8:27 am
From bad to worse.
Should have found something else to do today. Eedjut.
Post by dicky » Sun Mar 25, 2018 4:42 am
Bugger!
Dare I ask how you managed that?
You can get custom brake lines from HEL at a very reasonable price (ie, the same as the standard price)
Post by davamb » Sun Mar 25, 2018 5:43 am
Hey Dicky, I think my TRX front axle adaptor may be just a whisker too large in diameter with the result that the pinch faces don't meet. Combined with too much torque on the ratchet and allen-key combo and voila! She's a forked fork mate. In retrospect no need for it to have been done up that tight, I could loctite the adaptor in place and just nip up the two bolts.
Have grabbed another pair of forks from a wrecker off eBay and should have them by the end of the week, but it's money spent unnecessarily. I hate paying for my own stupidity, but no use crying over spilt oil. Lesson is to hurry less and think more.
Thanks for the brake line tip, yeah was thinking of braided replacements. Will check them out.
Post by cobbadiggabuddyblooo » Sun Mar 25, 2018 6:01 am
20Nm is their torque speck... That's a bit of a bummer
Post by davamb » Mon Apr 09, 2018 12:08 am
All back together over the weekend and out for a fang over the hills. Pretty happy with the result. Have the forks dropped a bit over 2cm through the clamps to accomodate the too-short brake lines and gotta say it feels so much better. Much more stable and no loss of agility. Reckon the stock R1 setup left the front end too steep. The extenders leave the forks the same length as the standard TRX jobs and with a couple of cm drop it all seems just right. Also don't feel like I'm going to grind my boots on every half-decent corner!
Post by cobbadiggabuddyblooo » Mon Apr 09, 2018 10:37 am
Spot on Dave.
That's why I went with a billet trees with stepped top yoke so I have the same 30mm offset and forks are at the same height as the Std TRX set up.
And the 40mm raised clip ons get them to the original height although mounted a little further forward.
I had them dropped 14 mm through the yoke for a short time but I'm quite happy with them back sitting flush. I took a total Std TRX for s quick ride 24 hrs ago realised why I went that route because the TRX just feels pretty good right from the start.
