Shorter sidestand
Shorter sidestand
Post by dicky » Tue May 19, 2015 7:30 am
Does anyone know of any sidestand to fit the TRX that are shorter than the original?
After my front end rework the bike is now lower and it stands up almost vertical when parked on the sidestand.
I'd rather not cut into my original stand, hoping to find another that bolts straight in but is a touch (1/2" should do ) shorter.
Re: Shorter sidestand
Post by davamb » Tue May 19, 2015 8:27 am
Be interested to see what you find Dicky, same problem here.
Post by cobbadiggabuddyblooo » Tue May 19, 2015 8:44 am
Check out the R1 side stand , I recall they may be the cure your after.
Post by dicky » Tue May 19, 2015 9:02 am
The R1 stand is an inch longer than the TRX stand.
Post by cobbadiggabuddyblooo » Tue May 19, 2015 9:25 am
Aaaah Ok, that's obviously what they use with shorter dog bones with the arse end raised.
Post by fung » Sun May 24, 2015 8:29 am
I'll have to check..but iirc early R6 ie 99/00 may have a shorter stand compatible.
grumpy1
Post by grumpy1 » Sun Apr 23, 2017 12:08 am
Anybody ever figure out the answer to this problem? R6 sidestand is longer than TRX as well
Post by Mincehead » Mon Apr 24, 2017 6:50 pm
Basically it goes like this: Buy another TRX side-stand and `doctor` it, SIMPLES. :wink:
