Inlet opening 13 / 53 closing. 2.3mm lift at TDC
Exhaust Opening 46 / 27 closing. 3.2mm lift at TDC
Static compression 12.5:1
Dynamic compression 9.4
Next fun and games will be to trim 0.5mm off from around the inside of an old MLS head gasket.
There is 0.25mm overlapping inside the bore.
Peter in at Comp. Coatings showed me how he trims his back with a dremmel and flapper to finish them off. I've got 3 old used MLS gaskets to practice on but if I cant manage it , I'll look at laser trimming the new gasket.
In the mean time I'll use the copper gasket again.
